AT 5th gear bypass?
Old Apr 15, 2015 | 12:40 PM
SpankyStokes's Avatar
Originally Posted by Patrick Bovee
ill be the uninformed noob to ask this question. I've only been in 5th gear after 100mph and you guys are talking about being in 5th gear at 40 mph.... even when I switch it from drive to manumatic its goes to 4th gear sometimes 3rd at that speed.
It does go into 5th gear in earlier speeds but is completely unnecessary. I don't know why idiots here think the car car will overheat without it. If anything being in 5th at such low speeds causes more of a drag on the drivetrain making the engine work harder than it would without the gear.
5th gear is only useful at high speed in my opinion. Driving around the city in 5th will just make the car a slob.
Old Apr 15, 2015 | 02:38 PM
herrschaft's Avatar
Originally Posted by SpankyStokes
As if I care! I personally asked for a profile delete. Never have I been to a forum where people have feet as hands and incapable of fixing anything. I got my diagram. I'm good to go. I feel sad for the useless duds here.
WTF are you talking about? You created an account this month yet you know everything about the members on this forum??? You obviously don't so you're an idiot for making statements like that. And you haven't searched very well since you don't even know the difference between Uprev and Rev-up. The majority of your responses in here clearly show your lack of knowledge (and maturity) on this platform so trying to argue otherwise is just dumb on your part. Keep acting like an immature little kid and you will get banned.
Now since you don't want to have the transmission diagnosed, how do you know there isn't "shrapnel" eating away at the inside? Your opinion of 5th gear is yours but it is unwise to overlook what caused the problem.
Old Apr 15, 2015 | 02:53 PM
yosip1115's Avatar
Your opinion is wrong. Driving around in 5th will not make the car a slob.
Mr. TCM expert, the transmission chooses what gear based on the load point. More load, lower gear, but speed is a factor in this decision that the TCM makes. When you want power, the load point changes and it will downshift if possible at the given speed.
So you got the wiring diagram, did you fix your problem?
Old Apr 15, 2015 | 03:16 PM
Spartan268's Avatar
You seem like a nice guy.
If you're currently in 5th and you switch to MM mode, the tranny automatically downshifts to 4th. Then you'll need to upshift again into 5th.
I cant remember what speed the RPM is at going 40, but you'll be able to shift into 5th if you're going at about 2100~2200RPM while in 4th. The RPM shift from 4th to 5th isnt very noticeable either unless you're in D mode and then the torque converter locks up. You'll notice it dips down even more as if you're in a non-existant 6th when the lock-up occurs.
Old Apr 15, 2015 | 03:26 PM
herrschaft's Avatar
He didn't fix his problem, the kid is too busy sending PM's:
Take your two pennies and shove me up your *** along with the ****** you casually insert daily.
What an intelligent teenager we have here...
Old Apr 15, 2015 | 03:30 PM
Spartan268's Avatar
I noticed that when I creeped his account.
But seriously...
Old Apr 15, 2015 | 04:03 PM
ldg870's Avatar
Bad idea not to fix it. The longer you put it off, the worse and more expensive it will be. You may just need a good transmission service now. Or a new trans later.
Old Apr 15, 2015 | 04:45 PM
Patrick Bovee's Avatar
Thanks I will have to try this out after work ! I joined to learn not to troll
Old Apr 15, 2015 | 04:52 PM
Urbanengineer's Avatar
I noticed that when I creeped his account. But seriously...
That is not what advice animals are for!
Old Apr 15, 2015 | 09:05 PM
G2B35AGN's Avatar
Actually this is one of the things I like about the car. Torque. I think it is great that it will just power along without having to work at it. Up hills, no downshift. Just kinda going along nice and relaxed. Low stress. Cool. Calm. Easy. You should try it sometimes instead of always blazing a comet trail. You'll last longer.
Old Apr 15, 2015 | 09:40 PM
JOKER's Avatar
CLUB MODERATOR
how do you know that you are in 5th gear? Do you shift manually? If yes, you need to start shifting to fifth at 40 or you will burn your trans fluid.
The "D" mode actually shifts gears at even lower rpm than I usually do when in manual mode. I usually shift at 2500-3000 when in manual, when in D it shift around 2000-2200. So it get's up to 5th at roughly 40mph. If you switch from D to manual it will automatically downshift to 4th. So if this is how you determined that you are always in 4th, you are wrong. You always in 5th.
Old Apr 15, 2015 | 09:43 PM
JOKER's Avatar
CLUB MODERATOR
The OP either needs to get some, or got too much of something.
Who walks into to the forum with that kind of attitude?
I bet his next thread going to be "How to bypass 5th cylinder"
Old Apr 15, 2015 | 09:57 PM
Hogbone's Avatar
Wait so you actually drive you a/t coupe like you would a stick, like all the time? Where is the fun in that?
Old Apr 15, 2015 | 11:53 PM
JOKER's Avatar
CLUB MODERATOR
I do, all the time. The fun is in shifting your gears at rpms you want and at the same time have a convenience of D when I need it (in traffic)
Old Apr 16, 2015 | 04:52 AM
  #30
Hatchman's Avatar
Please don't feed the troll.
