Airbag light flashing, reset only temporary
Old Jun 4, 2015 | 05:31 PM
willmkent's Avatar
hey guys,
My airbag light has been flashing, I did the procedure to reset the light but it only stays off for a little while, then it comes right back on. any idea why it might be doing this?
Old Jun 22, 2015 | 12:32 AM
pabguzman's Avatar
bump
I'm having the same problem...
Old Aug 5, 2015 | 07:31 AM
flytim3's Avatar
bump I am having this issue as well. Mine stays off for about a week or so then it comes back on.
Old Aug 5, 2015 | 03:39 PM
spitfingers's Avatar
I was having a similar issue, I heard there are zip ties holding the airbag connector under the drivers seat that causes a loose connection when the seat moves back and forth. I was lazy and just stopped my seat from moving. I'm not sure if this helps at all, but since ive stopped my seat from moving I haven't had the light on.
Old Sep 5, 2015 | 01:25 PM
flytim3's Avatar
I will confirm what spitfingers said. I haven't moved my seat at all for the past month and the air bag light hasn't come back on.
Old Sep 6, 2015 | 04:32 PM
JKL1031's Avatar
take itto the dealer. the have to fix it up to 120k.
Old Aug 30, 2021 | 01:23 PM
MightyMel's Avatar
Basic
Airbag light flashing, reset works temporarily.
So relieved to see that I am not the only one experiencing the saga of the flashing airbag light! I will reset again, then not touch my seat adjustments. Will report back on the results... :-)
Old Sep 4, 2021 | 11:28 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Pull the code so you know EXACTLY WHICH COMPONENT is malfunctioning.
Old Nov 23, 2021 | 11:54 AM
jk319's Avatar
Infiniti G35 Sedan Automatic no mods
I've had the same issue for last couple of years. I've cut the zip tie apply dielectric grease to connector and re-connect but the light came back on.
Anyone had a smoking gun fix that they can share?
Also, I hear that Infiniti took care of the problem under recall for certain VIN. Anyone got theirs fixed under the recall?
Old Nov 24, 2021 | 08:06 PM
cleric670's Avatar
BANNED!!!
Like my previous post, pull the code and see EXACTLY which component is malfunctioning. You can put the SRS system into diagnostic mode and it will flash a sort of morse code to tell you exactly what component is the problem.
Luisgalvan33
Jul 19, 2018 08:16 PM
poker_lamina
Sep 1, 2015 09:04 AM
leli_11
Aug 10, 2015 08:25 PM
ghost_g35
Aug 7, 2015 10:31 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
