New to the G family, I Need help
Old Dec 21, 2019 | 01:36 AM
Davar26's Avatar
06 get sedan with a sports suspension,sun roof, and spoiler.
Originally Posted by Terry_G35
Hey everyone I'm new to the club and very excited to be part of this. I need help, i recently purchased a 2003 g35 coupe with 133xxx miles on it. The same day I bought it there was an issue. As I was driving(cruising speed) the car stalled and turned off on me. I restarted it again and kept driving. Then it happenes again a few minutes later and I proceeded to restart it and keep driving. All of a sudden the car starts shaking and smoke came out of the passenger side of the engine. At first I thought it was the brake rotors or something but it couldn't be that. So I let the car cool off and tryed restarting it but it just kept kicking and not starting. So I put coolant in an the car started >>BUT<< White smoke started comming out of the exhaust pipes. I don't know what to do. The guy who's is fixing it said it was the coil pack and spark plugs was the cause is that true please help. What is the real issue here?
How much to fix?
Should I just get rid of the car?
you may have a blown head gasket.
Old Dec 30, 2019 | 11:32 AM
aaron.demming's Avatar
2006 Infiniti G35X 2WD Sedan
Check your cabin air filter if you here rattling when you use your AC. I had a noise when I used my AC that sound like a leaf being blown around and once I changed the cabin air filter (did it myself watching a Youtube video) there were a bunch of leaves in there. Cabin airfilters are less than $20 and if that doesn't fix the noise at least you have eliminated a possible cause.
Old May 9, 2020 | 01:33 AM
Steve Voller's Avatar
aftermarket Exhaust and custom rims
I guess your car was shutting down because of heat. Too bad you didn't notice it was getting so hot. So antifreeze would have run into your cylinders and ruined your bearings. Replace the block.
Old May 9, 2020 | 01:39 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
This car has already been fixed as per the original poster about halfway through the thread.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Tmatheso
Dec 13, 2015 03:24 PM
MrIP35
Oct 25, 2015 11:13 PM
