Pls don't die
Old Jan 31, 2018 | 01:20 AM
RA122223's Avatar
Pls don't die
The title is pretty much what I pray every time I throw my car into neutral or step on the clutch after moving. I just changed out my steering wheel so of course I had to pull the battery so the air bag won't blow up in my face lol but after doing so, my car will sometimes die when I come to a stop. It doesn't always happen and sometimes my car catches itself at around 300-500 RMP and then goes back to normal but other times, it will just drop and die. I tried doing my closed throttle body relearn, idle relearn, and accelerator position relearn to no success. Just wondering if anyone else had any ideas on what to try next? She idles fine when I start her up, its just after driving and putting it in neutral is when it drops really low. Any help would be greatly appreciated! Thanks all!
Old Jan 31, 2018 | 02:18 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
ECU reset as well, check for obvious vacuum leaks, check for a stuck open pcv valve.
Perform the idle air reset AGAIN after the ECU reset. Make sure the engine is up to operating temp before you do the idle reset or I guarantee it won't work properly.
Old Feb 2, 2018 | 09:49 PM
RA122223's Avatar
Thanks, I'll try this asap and let you know how it goes!
Old May 22, 2020 | 06:40 PM
Eric12312343's Avatar
2005 g35 with a k and n CAI and nvidia exhaust
I just looked for some vacuum leaks and there was one of the hoses that was loose, I am using high pressure lines, after I tightened the line and did a idle relearn and ECU reset my car no longer has shutoff, so hopefully I fixed it. Thanks guys
Chrisbk
Apr 21, 2020 07:27 PM
MADtotheA
Jun 16, 2011 04:21 PM
Maciuniu
Jun 5, 2011 10:10 AM
Tollboothwilley
12
Feb 26, 2009 01:13 AM
1fastsedan
Sep 8, 2006 12:24 PM
