Motor mount nut. Can't get to it. Please help.
Old Apr 25, 2016 | 10:20 PM
Sepsis's Avatar
Hey guys, I'm new here, but I've owned my 03 G35 for a little while.
The drivers side motor mount is bad, so I purchased a new one.
I put the car up on my lift, and the bottom nut was easy to remove, but I can't find a way to reach the top nut.
I tried from the top, but a socket won't fit because of the heat shield/exhaust, and I tried from under the car, but a wrench won't fit because of the tight clearances.
Normally, I can figure stuff like this out pretty quickly, and on my own, but this thing has me stumped.
How do I get it out of there? Any help is appreciated.
Hope this is the right section for this.
Old Apr 26, 2016 | 10:31 AM
BradMD_96's Avatar
I used a flexible head rachet spanner. I think I've also done it by removing the four bolts holding the engine mount to the block, using a flat spanner and something else for leverage. There really isn't much space in there though.
EDIT: Driver side is much easier to access, a flexible head spanner should do it.
Old Apr 26, 2016 | 11:23 AM
Sepsis's Avatar
Thanks.
I'll have to go get a set of the flex head wrenches.
I have a ton of tools, except those lol
stock.devon
Lighting
Mar 14, 2016 10:03 PM
Jiggs1219
Feb 25, 2016 08:30 AM
Snazzysara
Feb 23, 2016 02:46 PM
roboeclipse
Lights
Feb 23, 2016 01:47 AM
frodos_4door
Feb 20, 2016 01:08 PM
