Power steering pressure sensor (please help.. starting to lose it)
Old Jul 18, 2017 | 09:37 PM
DriftRoundUrMum's Avatar
Posted a couple other threads but can't seem to narrow my issue(s) down.. Previous thread with entire story below:
https://g35driver.com/forums/general...27-no-cel.html
03 G35 coupe / 5AT / 120k miles
Long story short.. Currently being plagued with a P0550 code. I just need to find out of this sensor has any correlation with the Knock Sensor?
Experienced loss of power randomly one day.. Night to day difference here... Lowered MPGs.. Sometimes a not so steady idle as well. Consult pulled P0327 & P0550 (knock sensor short or open cirq. & power steering pressure sensor high input)
Ended up changing the the knock harness (Z1 motorsports) P0327 went away and replaced with P0328 (knock sensor high input) so i changed that out as well. I now have P0550 (never went away) & P0328.. Still have no CEL or any other lights. Just codes, and loss of low end torque & overall smoothness
1) if the PSP sensor fails, will it put for sure put you in limp mode? Can't really find any evidence that supports this.. Spoke with Northshore Infiniti & the service guy said he "believes it can decrease performance when cornering" but that isn't exactly my problem.. Heard elsewhere that it can put you in full limp mode.
2) if in limp mode; can that trigger knock sensor codes due to retarded timing and possible low frequency knocks? Do these sensors communicate with each other at all?
3) if not question #2; can my P0328 be legit considering i used an Autozone AEM sensor vs the OEM one? Has anyone ever heard of a AEM KS just NOT working at all?
Any help, and advise is highly appreciated..
Thank you..
Old Jul 19, 2017 | 12:42 AM
victor0206's Avatar
I don't believe the power steering pressure sensor has any relation to the knock sensor. All it's really there for is for when you start the vehicle or if I am not mistaken hard cornering or times when power steering is really needed the car gets reading off of it to regulate the engine rpm so the vehicle won't stall out. Had to replace mine for different reasons but after having that pending code for too long. No loss of power from it
Old Jul 19, 2017 | 02:11 AM
So you had the P0550 code? But no performance issues? The sensor itself was the fix to that code? This kind of throws me off as I've heard from a few other resources that it can throw you into limp.. Conflicting info
Old Jan 23, 2022 | 11:20 AM
Mc5150's Avatar
Infinity g35
How did you change the sensor
Where is the sensor located to be able to change it
Old Jan 23, 2022 | 11:59 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
DGrantG
Apr 23, 2019 08:48 PM
DriftRoundUrMum
Jul 18, 2017 09:11 PM
DriftRoundUrMum
Jul 18, 2017 05:33 PM
dsmbill
Jan 4, 2011 08:55 PM
masterdave
Jul 13, 2010 03:53 PM
