intake/exhaust Valve not "rotating"
Old Feb 4, 2018 | 02:34 PM
Hisannah's Avatar
Apparently my gas mileage has collapsed because of a sticking valve not rotating in the valve guide as it reciprocates.
Can anything "simple" resolve this without disassembling the engine?
Old Feb 4, 2018 | 03:54 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That's not how it works, yes valves do continually shift and rotate (hence why you lap valves) but it's not something that is controlled. Who told you this and what makes them thing it's in ANY WAY related to fuel economy...
Usually a sticking valve is due to damaged guides, you also usually have a puff of blue smoke from the tailpipe when you first start the engine in the morning (but not blue smoke at high rpm or under load which usually means piston rings).
You can also have a sucked valve that is physically damaged but that's extremely uncommon on a stock motor.
Rudy Classic
Aug 4, 2016 11:53 AM
riverside20
Dec 18, 2012 01:37 PM
dyenboy
Apr 6, 2006 05:47 PM
Brian-g35
Feb 6, 2006 03:19 PM
acurasixty
May 13, 2004 07:47 PM
