Knock Sensor Harness
Old Apr 16, 2018 | 04:48 PM
bjhopp60@gmail.'s Avatar
2004 G35 Sedan. How many hours labor or minutes to replace knock sensor harness ?
Old Apr 16, 2018 | 05:37 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Remove the upper/lower plenum, lower collector and fuel rail, probably 5 or so hours. Pull the fuel pump relay and crank/run the motor till it stalls to relieve pressure. There is no bleed valve factory installed.
Old Apr 17, 2018 | 07:24 AM
How long to replace knock sensor harness only ?
Old Apr 17, 2018 | 12:25 PM
cleric670's Avatar
BANNED!!!
You have to disassemble all that stuff to get to the harness, it's buried underneath the intake and fuel delivery system. It's bolted to the top of the motor, look inside that little rectangular hole at the bottom of your intake manifold and you can see it with a flashlight.
Some folks in the past have been able to use a long piece of coathanger, needle nosed pliars, magic, and trickery to replace the harness but I've never tried so who knows.
dsheldon924
Jun 27, 2017 07:26 PM
rawfuls
Feb 11, 2017 06:41 PM
draxsonimy
Oct 22, 2016 05:47 PM
stefelz
Oct 22, 2016 02:41 PM
doranfreeman
Aug 17, 2016 05:17 AM
