G37 A/C driver/passenger temp issue
Old Apr 24, 2018 | 10:09 PM
XDR-V35's Avatar
Just got a new to me 2009 G37 Sedan. Today I noticed that the drivers side vents are blowing cold (AC set to 60 on both sides), but the passenger and rear vents are luke warm.
Turned both to full heat and both blow hot.
Sounds like a blend door or something similar, but not familiar with how these cars are setup for HVAC. Tried looking at the FSM for diagnostics, but did not get too far.
Any suggestions?
Old Apr 24, 2018 | 10:28 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Look up how to put the AC controller into diagnostic mode, it will cycle through everything and you can verify blend door motor failure with it. I also recommend taking the cabin air filter out so you can get an inspection mirror and flashlight up into the ductwork to inspect it from the inside. Might just he something in the ductwork sticking the blend door. Large dead rats or the positive battery cable cap or something.
Old Apr 24, 2018 | 10:38 PM
XDR-V35's Avatar
I tried the diagnostic mode (DIAGNOSIS SYSTEM (UNIFIED METER & A/C AMP.)), but it didn't seem to do anything and make sense...
For the first part, the only action I got was turning the drivers side up, when it hit "41" on display the ac kicked on with fan, then next was "51" with no noticeable action. Every action after that had no noticeable action.
bugeyetex
Interior
Mar 7, 2017 01:25 PM
kamikazeiG35
Canada
28
Sep 19, 2010 01:55 AM
EvolutionGSR
14
Aug 16, 2008 04:52 PM
mygiantcircle
Jun 27, 2007 12:01 AM
