weird metal noise
Old Sep 3, 2018 | 01:05 PM
RasputiPR's Avatar
weird metal noise
Hey i have a g35 coupe every time i get passed 55mph makes a noise on driver side like if it were metal with metal scrapping together and i really dont know what it is any help!!!!!
Old Sep 3, 2018 | 03:14 PM
Urbanengineer's Avatar
Maybe your rear brake is dragging or something. See a professional mechanic.
Old Sep 4, 2018 | 09:47 AM
jbarnett250's Avatar
maybe a splash guard dragging the ground? i don't usually hear new noises at high speed because there's so much wind noise or road noise. but one that does show up like that is if you have a loose splash guard. it doesn't hang down until you hit high enough speed and then it drags the ground and sounds like scraping. it's like this on my sedan but i assume the coupe has something like this too. it may not be obvious as the thing goes back to it's normal position when you stop. easy to check for by sticking your head under there and looking for sanded down edges of your splash guard pieces or front part of fender liner that meets the splash guard.
magnetism80
19
Feb 15, 2017 11:01 AM
Lord Trazaza
Nov 14, 2016 12:42 PM
Ferrah
Oct 22, 2016 09:28 AM
Marcel
Apr 19, 2003 07:32 PM
KongzGx
19
Jan 18, 2003 04:06 AM
