Car Keeps Dying
Car Keeps Dying
ok so my car keeps dying if not started for about a full day. Jump it and starts and runs fine, and starts fine throughout the day but when it sits it doesn’t start, it it goes 2 day: it just completely dead no lights or anything.
Things ive done:
1) Battery Tested Good - From autozone
2) Starter Tested Good - from autozone
3) Alternator Tested good- from auotzone (on car)
4) Connection were clean, but I cleaned and sanded slightly anyways
after these 4 the car is still dying, heard maybe a power wire from Bat to alt. But it seems like it charges fine since the car can turn on and off just fine after a drive, seems to be a drainage issue but I could be wrong
what do y’all think? Things I should check, quick look in fuse box didn’t see anything blown, didn’t do a full check but all systems work well, and no I did not leave anything on.
Need to know ASAP! Thanks
Things ive done:
Google "How to check battery voltage" and see what happens
Have friend crank car while you look at multimeter.
My 2 cents are on drainage issue. Google "Check battery drain DIY" Mine does the same thing but it needs to sit for 2 weeks not two days.
Unplug the fuse for the CD changer and see if the problem goes away, if you have ANY other electronics installed start pulling fuses u til you find what's drawing current.
