Vibration and hum when accelerating
Old Aug 27, 2019 | 05:14 PM
Klutes's Avatar
Hoping I could get some help. I have an 06 coupe auto and when I go over 60mph and accelerate I get mild vibration felt through the floor and a low hum coming from what I think is the rear end. It gets louder and more intense with vehicle speed but is only felt and heard when accelerating. If I let off the accelerator or keep it under 60mph the sound and vibration goes away. Any ideas? I suspected the wheel bearings but haven’t had any play or resistance in them when checking. Maybe something in the driveshaft?
Old Aug 28, 2019 | 11:01 PM
Klutes's Avatar
Anyone?
Old Aug 29, 2019 | 04:43 AM
Scorpi0's Avatar
Vibrations are a b!tch to figure out. Does it make a difference what gear u are in?
Old Aug 29, 2019 | 03:45 PM
Klutes's Avatar
Yea I know they’re the worst! It does not make a difference (I’m auto btw) I’m going to check inner cv joints and wheel bearing again this weekend.
Old Sep 4, 2019 | 09:16 AM
Zach Gaston's Avatar
G35 sedan built short block
Same issue with vibration at 60mph
It’s only first thing in the morning. If I hit the highway first 60mph vibrates rear end. It is gone after that for some reason. I suspect a rear hub or cv axle is to blame. I’ve been thinking about upgrading the rear axles anyway to the 370 set up with new hub assembly’s.
EricDJ
May 19, 2019 09:49 AM
TigerWoodsIV
Dec 1, 2015 06:48 AM
StockG35Sedan
Apr 28, 2014 01:35 PM
strcdan
Feb 18, 2010 08:06 AM
gtrefever
Oct 23, 2009 12:45 AM
