G35 in limp mode.
Old Jan 2, 2020 | 04:37 PM
Lil_Spanish's Avatar
I have a 2005 g35 coupe automatic tranny
G35 in limp mode.
Ok I have a 05 g35 6mt and I was going turning in an Intersection when my car went into limp mode. The ses light, slip and vdc light came on and would drive very slow. This happened before once a while back and pulled codes: P2138 P2122. Didn't put much attention to the codes because I disconnected battery and it didn't come back till now
Here's the vid of what it does:
Old Mar 12, 2020 | 07:01 AM
Ethan K.'s Avatar
Red 6MT (Rev-Up) Coupe
Try an accelerator pedal re-learn, then if that doesn’t help, take a look at your throttle body, maybe even clean it to see if it helps.
Old Mar 12, 2020 | 11:40 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's the accelerator pedal itself, those codes are the ECM telling you that there is either a short, an open circuit, or an unexpected value returned from the accelerator pedal.
The pedal is just an electrical switch, there's a harness on the side of it, inside are two rheostat switches (extra one for redundancy when the first one fails) that deliver between 0.5 and 4.8 volts to the ECM depending on how much you press the pedal.
It's a fairly common failure point, you can replace just the switch without needing to buy the entire pedal assembly, it's about $35 for the switch. You will need to perform the APP relearn procedure steps in the FSM, section EC - Engine Controls under "basic service procedures" at the start of the document.
Old Mar 12, 2020 | 11:41 AM
cleric670's Avatar
BANNED!!!
AnonG35
Apr 19, 2018 07:56 AM
Avarian
Dec 28, 2016 06:17 PM
Underw00d2
Jul 2, 2011 12:08 AM
infinit G
Dec 2, 2008 12:43 AM
Jason kiDD
Aug 23, 2005 11:14 PM
