Clutch pedal issue
Old Feb 3, 2020 | 03:40 AM
wilhelmdon's Avatar
Clutch pedal issue
My clutch pedal does not spring back up. It gets stuck down when pushed and I Had to manually pull the pedal back. Transmission won’t engage. Any advise is greatly appreciated. Thanks.
Old Feb 3, 2020 | 08:29 AM
telcoman's Avatar
Veteran: Army
Clutch Slave Cylinder
Google it!
Old Feb 3, 2020 | 11:14 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's the clutch master cylinder, common issue with the G35/350Z. The best route is to rebuild both the CMC and CSC, when I put in a new transmission last year I bought the OEM rebuild kits and it was under $50 for both. Use Motul 600 fluid and I STRONGLY recommend buying a good stainless steel braided flex line, and some heat wrap because a section of the line is very close to the headers and it's a weak spot in the system.
Total price tag for everything was under $100.
bchalks
Drivetrain
Dec 2, 2015 08:24 PM
Blackg3506
Oct 23, 2013 03:45 PM
dcryan90
Sep 2, 2010 11:53 AM
mal_TX
Drivetrain
Jun 14, 2007 12:38 AM
