The ac coming hot in 61f
Old Mar 8, 2020 | 05:56 AM
alimohammad008's Avatar
Infiniti g35
The AC Coming hot in 61f and cold in 60 f
please help me and the air coming worm when I drive
Old Mar 8, 2020 | 09:51 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Is the compressor cycling off or staying on when it gets hot?
What does the ambient outside temperature read?
Old Mar 8, 2020 | 12:40 PM
Infiniti g35
the temperature out side not reading correct
Old Mar 8, 2020 | 01:03 PM
cleric670's Avatar
BANNED!!!
I suggest taking the vehicle to Nissan for a diagnostic, it's a very complicated system that includes ambient sensors, sunload sensor, 9 different switches, a variable pitch compressor, a PCB/ROM digital controller using CAN to talk to the BCM, ECM, and IPDM and a lot of various other components that are difficult to troubleshoot. The dealership Consult-II tool has an automatic test function that will tell you exactly what the problem is, additionally they can look at all the values for things like the ambient temp sensor to see what value it's sending back.
You can try using the AC diagnostic mode but I doubt it's going to help you much, section ATC - Automatic Air Conditioner in the FSM. Look for "diagnostic mode".
HOWEVER, if your outside ambient sensor is not functioning properly and displaying the correct outside temp then the system WILL NOT WORK PROPERLY. It uses both sensors to determine if cold/hot outside air is injected into the system. Try unplugging the sensor and look for any corrosion in the harness or on the sensor. When you plug the sensor back in it will display the maximum temp value which is like 125F for about an hour until it recalibrates.
https://www.nicoclub.com/infiniti-service-manuals
Old Mar 9, 2020 | 10:41 AM
FreshLikeAG's Avatar
sunload sensor
Interesting. I noticed recently when I take my sunshade down right away the A/C cranks up a little
Old Mar 11, 2020 | 11:48 AM
cleric670's Avatar
BANNED!!!
MODERATOR: Copied from duplicate thread.
Originally Posted by alimohammad008
I have infiniti g35 Sedan 2006
the air coming hot in 61f and when you turn ac off the air coming worm after 15 or 10 minutes driveing it should be open the windows or turn ac on on 60f
out side tumpricher the sensor not reading correct
cleric670's Avatar
BANNED!!!
Read my reply, post #4
GeeBruce
Jul 11, 2017 07:01 PM
Adrian90744w
Feb 8, 2013 09:35 PM
jcv423
Jul 10, 2008 12:46 AM
robinchen
Nov 19, 2007 02:07 PM
brianmfournier
Sep 21, 2007 08:26 PM
