Drivers window goes up when door is closed
Old Mar 19, 2021 | 08:49 PM
Angler86's Avatar
G35 Coupe
Every time I close my drivers door with my car shut off and windows down the drivers window and only the drivers window goes up on its own. Can someone tell me how to stop this? My windows go down an inch as normal when the doors are opened and back up when they are closed, and the window up and down functions from my key fob or by putting the key in the door and turning twice works properly. I just can’t figure out why the drivers window goes up every time the door is closed. Please help.
Old Mar 19, 2021 | 09:22 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Check to see if it's actually the door closing mechanism or the physical act of closing the door.
Do whatever you normally do to make this happen but don't actually shut the door, instead reach down on the door jamb (chassis side) and depress the door switch.
Your window should roll up that tiny amount after that switch is depressed, it should not actually roll your window all the way up if the window is currently rolled down.
Report back with your findings.
Old Mar 20, 2021 | 07:58 AM
Angler86's Avatar
G35 Coupe
Findings
With the door open I pressed the door switch and the window rolled its self back up.
Old Mar 20, 2021 | 01:48 PM
cleric670's Avatar
BANNED!!!
Ok it should only roll itself up 1/2" to tuck under the window sash, this will also only happen when the window was already rolled all the way up, it should have no effect whatsoever if the window was rolled down ANY amount.
If your window is moving up even when the window WAS partially rolled down then I would first recalibrate the window motor. Follow the steps on this page it's very simple.
https://www.infinitihelp.com/diy/gco..._procedure.php
Old Mar 20, 2021 | 05:05 PM
Angler86's Avatar
G35 Coupe
I’ve already done the reset many times to no avail. It does do the 1/2” movements when the windows are up as it should. The problem is when the windows are down it puts the drivers window all the way up when the door is shut
Old Mar 20, 2021 | 09:48 PM
cleric670's Avatar
BANNED!!!
I suspect something is wrong with the door key switch, unplug it and see if the problem persists.
Infing35x
Mar 14, 2014 05:58 PM
knucklehead
Oct 1, 2010 07:49 PM
Petoria
Aug 25, 2006 02:41 AM
urabus
Canada
16
Nov 28, 2005 05:18 PM
Ehrpower
Jun 14, 2004 07:24 AM
