TPP APS limp mode 2122 code troubleshoot
Old Mar 11, 2022 | 08:45 AM
matt2006g35's Avatar
2006 G35 w/ AT & Aftermarket headers, exhaust & trim
Exclamation TPP APS limp mode 2122 code troubleshoot
*TPS *P2122
Replaced & relearned throttle position sensor, no luck. Spacer for the pedal body is fine & intact. Getting low voltage on pin D. Need help to what to look for next. Wiring seems to look good at relevant connections. Checked out everything except voltage at ECU. VDC off & SLIP lights only.
Old Mar 12, 2022 | 09:47 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
P2122 is the APP switch not the throttle body/throttle position sensor.
Replace the APP sensor/switch.
jordan lee
Feb 15, 2021 06:43 PM
relias33
Feb 28, 2015 05:01 AM
Joseg35
Oct 15, 2014 02:20 PM
abahl
Mar 12, 2013 05:16 PM
Beni B
11
Feb 25, 2009 07:47 PM
