Vdc off, slip and service engine soon lights come on
Old Feb 23, 2009 | 10:12 PM
Beni B's Avatar
Hello Everybody,
For a while my car has had a little problem staring. It hesitates at start up, but it starts.
Today I was driving and the vdc off, slip and service engine soon light came on simultaneously. The car went into a pilot mode, it did not accelerate, it just rolled really slowly. Autozone hooked up this gadget to the obdII and came up with code P2135.
Has anyone else experienced this promlem? What could it be?
My car is a 2004 Infiniti G35x with 62000 miles.
Old Feb 23, 2009 | 10:21 PM
Idyfohu's Avatar
What's the code? If you haven't, do a quick search and find out what it is so that you know what's wrong. I'm guessing a sensor went out...that really sucks. I had a similar problem after leaving my car outside in cold weather (my car is always garaged) and my car was in limp mode, but after driving it for a minute or so, I turned it off and back on and the problem mysteriously went away.
Check what the code is saying is wrong, that's your first step and then take it from there. GL!
Old Feb 23, 2009 | 10:24 PM
maciejk's Avatar
http://www.infinitihelp.com/Ownership/Common/codes3.htm
throttle positioning sensor
Old Feb 23, 2009 | 11:07 PM
Beni B's Avatar
The code is P2135. I read some reviews and everybody states something different. The most common reply I read was about the throttle position sensor. Is it hard to replace the throttle position sensor? I know it should be located by the throttle body,by the MAF sensor.
Old Feb 23, 2009 | 11:10 PM
tragedycat's Avatar
Shouldn't this be covered under your powertrain warranty? I had a similar problem a few months ago, happened to be a camshaft position sensor, and it was replaced at no charge.
Old Feb 23, 2009 | 11:19 PM
Beni B's Avatar
my car is a 2004 with 62000. It might still have the powertrain, but I don't think the powertrain will cover the TPS. I can do it myself, it cant be that hard. I hope not.
Old Feb 24, 2009 | 04:01 AM
4drmadness's Avatar
I had the same code, u need to get a new throttle body chamber. This will be covered under powertrain warranty. pm me if u need more details
Old Feb 24, 2009 | 08:43 AM
Beni B's Avatar
Thank you for the edvice. What throws me off is that some people say it is the throttle position sensor and others say it is the throttle body chamber.
Old Feb 24, 2009 | 12:15 PM
dhl's Avatar
dhl
Just had the same problem on Saturday and the dealership said it was the Throttle Postion Sensor, but they replaced the whole throttle body to remedy it. They said it is so common that when I said VDC Off, Slip and TCS light they knew it was the TPS and then confirmed it when they pulled the error code.
Old Feb 24, 2009 | 07:47 PM
Beni B's Avatar
I just came back from the dealer. They replaced the throttle chamber. The dealership told me I need to replace the MAF sensor as well. However that is not covered by the powertrain warranty. I told them not to replace it and the car runs fine. The throttle chamber was covered by the powertrain warranty. They wanted 435$ for the MAF sensor. I can replace that myself if i get a "service engine soon" light. The car runs like a champion now.
I want to thank all of you for your help!!!DOMO
Old Feb 25, 2009 | 12:51 AM
ttrank's Avatar
Grocery getter
Glad they took care of it for you.
Old Feb 25, 2009 | 07:47 PM
kswan53's Avatar
Before you replace the throttle body, (especially if you are out of warranty, I was at 85000 miles) you might want to have the throttle body cleaned. Lot cheaper. ($116.00)
I just had the same exact thing happen to me with a P2135 code. Had my local mechanic clean the throttle body. When he was done the car was idling too fast and I actullay got a P0507 code (Idle speed greater than 200 RPM over the set point). After he cleared that code, I went through the recalibration procedure to reset the throttle and accelerator pedal positions and reset the Idle Air Volume. You can find links to the procedures elsewhere on the forum, just study the procedure before hand and do each step as explained.
Worked like a champ and so far so good.
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
igking
Jul 19, 2015 01:12 AM
