Temperature all the way up but no hot air
Old Feb 12, 2023 | 06:33 PM
chipackers234's Avatar
2003 g35s sedan
I have my ac compressor unplugged from doing my engine swap because the new compressors sensor doesn’t match the plug. would this stop the car from also blowing hot air?
Old Feb 17, 2023 | 09:25 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Nope, if your engine is at operating temp and you have no hot air blowing from the AC then you have air trapped in the coolant system.
Primary reasons for this are not opening the purge valve to release air from the heater core hose, and adding coolant too fast. Add coolant at a rate of no more than 1 gallon per minute, that's a pretty slow pour.
When idling the car up to normal operating temp turn the AC controller to MAX HEAT and HIGHEST FAN SPEED, this will ensure the heater core is wide open and the valve isn't throttled back.
After the car has idled up to normal operating temp for the first time I like to blast down the road at WOT in first gear then SLAM on the brakes almost to the point of engaging the ABS. This will throw the weight of the coolant forward and displace any remaining air.
Old Feb 17, 2023 | 09:26 AM
cleric670's Avatar
BANNED!!!
Moving this thread out of the audio/video section and into the appropriate subforum.
ilyaat
Sep 13, 2007 07:06 PM
Mr. G
Mar 12, 2007 12:21 AM
Real240
Aug 6, 2003 03:29 PM
FaureG35
13
Nov 12, 2002 05:37 PM
