vdc, slip and abs light on?? || what plugs are these?
Old May 13, 2023 | 08:51 PM
trent_55's Avatar
2004 infiniti g35 manual sedan
Hello I recently swapped a (good obviously) junkyard vq35de into my 2004 g35 6mt sedan and I have two questions. First One being do you guys recognize the two plugs?(below) I cannot remember where they plug into? (Headlights are in now), and the second question being I have no codes but i do have a vdc light, slip light and abs light on and im not sure what the cause is. If this helps the engine was idling high until I did a throttle body relearn it now idles at 650 ish but pretty rough almost wants to stall. Im assuming my christmas tree dash is caused by these two disconnected plugs just need to know where they go to
If you cant tell Both of the plugs are in the front under the headlights grey is on the right side of car, black is on the driver side
Conissah
Jan 14, 2015 10:51 PM
nism0350gts
May 25, 2011 01:09 PM
B3N
Oct 4, 2009 03:26 PM
chrisv
Aug 12, 2005 05:48 PM
