OEM Power steering fluid
This is the oil I used to my G35 it did went 1/4 inch over max and now steering wheel is heavier than before? what is the problem? it is red color, is red color fluid suitable for G35?
One owner 2004 G35 Coupe 6MT
That fluid is fine. Did you top off a little, was there a lot missing, or were you refilling the system? What I'm getting at is you may need to bleed the system. Topping off a little wouldn't require that though.
