Hawaii Honolulu
help supercharger choices!
Old Jun 21, 2012 | 03:38 AM
iron man_808's Avatar
hello everyone...Im pretty much a noon at g35's
Drove a Subaru before.
the question I have is what supercharger should I go with for my 07 rev up g35?
I've heard things about tapped oil pan chargers & self-contained chargers...which is better & high rates now days?
Old Jun 21, 2012 | 03:41 AM
DrewDrew's Avatar
Vortech v3 may be your best choice. It's self lubricating so there's no need to tap your oil pan. A safe tune pushing 9-10lbs boost will put you around 400whp if that's what you're looking for.
Old Jun 21, 2012 | 03:43 AM
Oh yes I've heard the vortech used to have to tap the oil pan but now the new v3 is self-contained as well?
Old Jun 21, 2012 | 03:49 AM
Diff between v2 & v3
Also I heard v3 once installed it's hard to pull out the oil dip stick & check the level...since it's blocked off.
Old Jun 21, 2012 | 04:06 AM
DrewDrew's Avatar
v2 requires a tap into the oil pan. v3 is self contained.
I guess it's a little tougher. look at this pic for yourself.
doesn't appear any harder IMO.
Old Jun 21, 2012 | 04:13 AM
xr0ckstar's Avatar
Check out GTM !
Old Jun 21, 2012 | 05:02 AM
kahalawhat's Avatar
what do you consider a safe tune?
Old Jun 21, 2012 | 06:00 AM
Ok last thing I heard was the intake filter will get smashed & is hard to clean & replace.... It will become deformed after installment?
Old Jul 6, 2012 | 03:28 AM
Beasteggs's Avatar
I advise save your money and go turbo. I had a vortec set up was loud on my revup and it was alot of maintenance. PIA to clean air filter, align piping (very tight). The serpatine belt well get loose pretty so often (Gates brand) Couple times I threw belt on the freeway loosing power to everything. Plus the power was ok with all bolt on possible (389whrp) 2.87 pully ... With turbo set up you have alot more torque and it's easier to up grade to boost/hp.
Old Jul 29, 2012 | 02:13 AM
thanks for all the advise everyone.
I think I'm gone go turbo!
so question is now is it better to go single turbo or twin turbo?
Old Aug 1, 2012 | 03:05 AM
Beasteggs's Avatar
Depends on what you can afford and power level? Greddy 18g kit is good but is pricy and more for install. For single try look at Boosted Performance its pretty same price range as a vortec and has opitions for fuel and engine management, and future turbo upgrade is easier. Another plus if you have tools and mechanically inclined you could do the install.
Old Aug 1, 2012 | 02:04 PM
toogood131's Avatar
Old Aug 2, 2012 | 10:01 PM
GZire's Avatar
How much you want to spend is the question? TT is going to be a bit more complicated to install (and therefore more $$$).
Old Aug 2, 2012 | 10:19 PM
jninja26's Avatar
In general TT will have more low to mid range boost, and ST will have better high end boost.
Old Aug 2, 2012 | 10:21 PM
herrschaft's Avatar
If you give us a budget we can tell you if its doable or not. Although the SC's do lack torque, they are the cheapest form of FI and the easiest to work with. A single turbo obviously has less moving parts then a TT which is always a plus and both will easily provide the power on a stock block. There's also supporting mods that will be required that don't come with a "kit" so expect to spend more money there, along with the cost to install everything and have the car professionally tuned.
Start researching the subject. There's a lot of good information on this forum and even more on MY350Z.
seagrasser
May 3, 2022 09:43 AM
Mad A
DFW Classifieds
Mar 28, 2016 11:25 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
9tray turbo
Sep 29, 2015 10:22 PM
