View Full Version : Engine - Complete Motors
- WTB: cam timing gears (intake)
- FS: OEM Engine Cover
- FS: 04 G35 6mt engine and/or transmission
- WTB: VQ35DE motor
- FS SoCal: 03 Motor and Auto Trans
- FS: FS: Unorthodox Racing Crank and Idler Lightweight Pulleys
- WTB: upper oil pan (rev up preferred)
- FS SoCal: 05 Non Rev Up Timing Cover
- WTB: Power Steering Pump
- WTB NorEast: Polished Timing cover
- FS: Championship Street/Race Engine Comlete
- WTB: Fully Built VQ35DE. (For FI)
- FS: OEM Idler Pulley, Alternator/Power Steering
- FS: Non Rev-up SxExCx Polished Timing Cover
- FS: Unorthodox Racing Pulley
- FS SoCal: OEM valve cover
- FS NorCal: Brand New OEM Valve Covers & Valve Cover Gaskets
- FS: oem 350z engine cover
- WTB: rev-up exhaust cam and cam gear sprocket
- FS: COMPLETE MOTOR with Access and Upgrades 94k
- FS: 2004 Complete VQ35(DE) Engine Manual MT
- FS: 30k running 06 revup 600 plus shipping
- FS: Stillen Oil Cooler
- WTB: your leaking valve covers
- FS: Piston, Rods, L19 Studs,
- FS SoCal: Non Rev Up Heads for your turbo build!
- FS: ARC Radiator Pressure Valve & Combination Tank
- FS: Mystery Engine 04 VQ35DE
- FS: ARP L19's, Heads, Oil Pan, Crank, Timing stuff
- FS: VQ35DE engine & CD009 Transmission, Cheap must go
- FS: Radiator coolant pipe
- FS: Cosworth 8.0:1 turbo pistons
- WTB SoCal: I need ARC radiator cap (maybe other ARC stuff too)
- FS: 2004 G35 timing cover VQ35DE non revup
- FS: Minty fresh VQ35DE REVUP NA monster build
- FS: Sxexcx Polished Oil Sensors!!!!!! BLING!!!
- FS: OEM Valve Covers
- FS Canada: OEM Upper and Polished Lower plenum
- FS: ARC Oil Catch Can v2 with Earls Hoses and Fittings
- FS: Polished Cam Covers
- FS: Brand NEW Polished Alt & Idler pulley
- FS Texas: cam covers and upper plenum
- FS: oem stuff...oil pan, oil pump, rear coolant pipe, oil pick up, thermostat
- WTB: Looking for a 2005 Coupe AC Compressor
- FS: Non Rev up Valve Cover
- FS: Stock Cams, Heads, Oil pump
- WTB: Valve Lifter (hat) 802U or 802R
- WTB: Looking for a REVUP motor
- FS: Feeler VQ40DE bare block and heads
- FS: 04 non-revup heads with cams
- WTB: Non-Revup vq35de
- FS MidWest: VQ35DE and 6 speed trans
- FS SoCal: **********2003-2007 Valve Covers..**********
- FS SoEast: Piston, Rods, Studs, Gasket - New In Box!
- FS: bare block
- FS: Lower Plenum intake manifold
- FS: OEM DE Oilpan
- FS: OEM rear coolant pipe
- FS: CP piston Brand new
- FS: VQ35DE 04 45k Complete W Strup Headers
- WTB: Looking for a Bare Block
- FS: (3) NAPA Gold oil filters (1) OEM oil filter $20 shipped
- WTB: ** VQ35 DE Rev Up heads **
- FS: OEM Crank Pulley
- FS SoCal: G35 Complete Part Out - Cosworth, APS, Carbonetic, Stop Tech, Tein etc...
- FS SoEast: VQ35DE block w/ upper oil pan. Local pickup
- WTB: A heap of forged internals
- FS: OEM G35 engine cover
- FS NorEast: UR Pulley Polished - fan/idler
- FS NorEast: Polished Fuel Delivery Piece
- FS: Lower Runner under the plenum
- FS SoCal: 04 oem upper plenum
- WTB NorCal: oem power steering tank
- WTB NorEast: 2009 FX35 Engine (Complete Longblock)
- FS: Wrinkle Black Powdercoated Timing Chain Covers
- FS: Rev Up Oil Pump
- FS: APS Oil pan w/ Fumuto Drain Valve
- WTB: complete VQ35DE (03-04 AT, prefer less 60K)
- FS SoEast: Brand New Vq35de OEM Crankshaft
- FS: UR Polished Alt. & Idler Pullies, OEM VTC Sprockets
- FS: Cosworth Headgaskets, Solid motor mounts, ARP L19's
- FS: **vq35de**
- FS SoCal: Polished Timing Chain Covers
- FS: EAGLE RODS (brand new) for VQ35DE
- FS: Stainless Solid Motor Mounts !!!
- FS SoEast: DE headgaskets
- WTB SoEast: Need a A/C Compressor Clutch
- WTB: 06 rev-up motor
- FS Texas: motor
- FS Texas: stock motor
- FS: Built short block brand new
- WTB: Complete VQ35DE
- WTB: 05/06 rev-up motor
- FS: Unorthodox Crank Pulley with Belts
- FS: Brian crower valve springs and retainers
- WTB SoEast: Complete VQ35de
- WTB: ACL thrust washers!!!!
- FS NorEast: VQ35DE rev up long block
- FS: 2006 VQ35DE 12,000 miles
