mrev2 buy or no?
Old Oct 4, 2006 | 05:47 PM
  #31
Hydrazine's Avatar
It all depends on where your A/F is starting at.
In any case, it will bump up the A/F a little. And this isn't necessarily a problem unless you are already close to lean or at lean.
If you see your car is running below 13.25, the combination won't be a problem. If you are running above 13.25, it will run about 0.2 to 0.4 points higher.
So it depends very much on where you are starting from.
Old Oct 4, 2006 | 07:40 PM
  #32
_jb's Avatar
_jb
Photographer
When you say 13.25, you mean at peak RPM, right?
Looks like it might be worthwhile to either get a A/F reading on a dyno or put in an A/F gauge before deciding.
Old Oct 4, 2006 | 10:48 PM
  #33
Diamond G35's Avatar
Guess I got lucky actually....
Talked to a few knowledgable folks and will disconnect the battery and do the brake pedal reset just to make the ECU relearn faster.
Old Oct 6, 2006 | 10:37 AM
  #34
Hydrazine's Avatar
No. Not necessarily.
It takes a little experience to know what is good and what is not.
Lean is actually worse at the TQ peak. You also need to look at the curve as a whole. Is all of it high? Or only at very low RPM? Its depends on a lot of factors.
You can post a plot here for a lot of good analysis.
Old Oct 11, 2006 | 10:02 PM
  #35
alfegobaca's Avatar
hi..has anyone changed their camshaft and if so what gains were trealized,,,?? and in order to do that you need to do something else too, i believe.......and what about throttle body...cant that increase some hp??
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
bigmike
Sep 17, 2015 01:58 PM
dorifto7
Sep 17, 2015 04:53 AM
mamba24
Sep 15, 2015 10:37 PM
twentyeggs
Sep 11, 2015 03:58 PM
