Why are plenum spacers so expensive?
Old Jun 6, 2006 | 12:52 AM
  #31
Dr_jitsu's Avatar
I am not sure what my AFR is. Since I am in Texas, I have access to 93 Octane. Plus, I did an ecu reset. There is no indication that I need a tune up or a re-flash. The bottom line is the car is definately faster now, and runs very smoothly.
I made this post when I first opened the MREV package w/ the spacer. After a couple days of driving, I have absolutely no complaints now.
I highly recommend this mod for an 05 or 06 (Rev-up).
I am not sure if I would put it on a non rev-up. I would probably just go w/ a spacer.
Old Jun 6, 2006 | 06:47 AM
  #32
Quickie's Avatar
Has anyone had any trouble with dealership warranty repairs with these mods in place?
Old Jun 6, 2006 | 08:56 AM
  #33
madchef's Avatar
I suggest you wait for a used spacer to be sold on the forum. Doesn't happen very often, but keep your eyes peeled
Old Jun 6, 2006 | 10:22 AM
  #34
Dr_jitsu's Avatar
Its a stealth mod, so dealer doesn't have to know. I left my engine cover off because it retains heat and reduces horsepower by 3.
When I take it to dealer I will simply put the cover on.
Anyway, dealer would have to prove that mod CAUSED a problem.
Old Jun 6, 2006 | 01:00 PM
  #35
Quickie's Avatar
True, they would have to prove it. Now if I changed the cams and the timing chain broke or if I bent a valve, that would be a different story. But doing mild mods to the intake really won't hurt anything. I stress the word mild. I was just wondering what kind of feedback the dealerships were giving in regards to mods and mod related repair work performed under warranty.
Old Jun 10, 2006 | 07:05 AM
  #36
egbplatinum's Avatar
what do u guys think of adding the mrev2 with 5/16 spacer on my 04 g35 and just getting a chip or whatever u guys said to fix the lean problem? is that the best thing i could do?
Old Jun 12, 2006 | 11:26 AM
  #37
Hydrazine's Avatar
Yes, that will certaintly add significant gains. And if you add a chip, it will also allow you to advance the timing and that is worth another ~10HP.
Adding a good exhaust will typically make about 8HP
Adding test pipes will add approximatly another 8-10HP
These are just rough numbers, but If you were to do all of it with engine management or reflash, you would have some very significant and noticable gains.
Old Jun 12, 2006 | 04:12 PM
  #38
Dr_jitsu's Avatar
Hi Tony,
As you can see by my subsequent posts I am very happy w/ your product.
I am about to add the Fast Intentions exhaust with the test pipes (for off road use only, of course). With these mods (see sig), should I get an ecu reflash? What about technosquare? Since I consider you to be a VQ 3.5 genious, I would greatly appreciate your input.
Old Jun 23, 2006 | 05:31 PM
  #39
johnadlertech's Avatar
Back to the original post. They do seem expensive when you figure that a whole new upper intake is not that much more.
Old Jun 23, 2006 | 10:59 PM
  #40
Hydrazine's Avatar
Originally Posted by Dr_jitsu
Hi Tony,
Sorry for the delayed response. I check the boards all the time but this thread didn't show up on my "new threads" link.
If you are getting the Exhaust with test pipes you will be well suited to get some kind of engine management. Particularly with test pipes!
You can do the standard reflash or even engine management.
Your direction depends on what your objectives are. If you really want to tweak/fine tune the most out of your car, get the EM. If you are generally happy with what you have and don't need much more, then get the reflash.
TS is quick and easy and cheaper. EM will give a more customized tune.
Different people will have different objectives so its a little difficult to say which one to do.
Heck. Some people do both!
Old Jun 23, 2006 | 11:08 PM
  #41
KenK2's Avatar
The Pole
Hey bro.. Clear your pm box as I need to get a spacer and not sure what to get for my '04 6mt..
Old Jun 23, 2006 | 11:11 PM
  #42
SWAT311's Avatar
Originally Posted by 99atlantic
.....remove your ****ty plastic cover (and who really wants that POS on their engine anywyaS)
I like the cover. Thanks. =)
Old Jun 24, 2006 | 03:28 PM
  #43
Dr_jitsu's Avatar
Wow, people are still responding to this old post....as long as I have Tony's attention, what do you think of UTEC vs Emanage Ultimate. Both allow A/F adjustment and timing advance. The UTEC will lift the rev limit, but my car loses power after 6200 anyway, so I shift before 7K.
As you can see from my sig, I am going w/ the EU (That is what SGP racing, who will be doing my tune works with....well they also love the F-con, but I don't have 3K for Emanagement).
Old Jun 25, 2006 | 12:56 AM
  #44
Hydrazine's Avatar
Both are good. You can't go wrong with either.
Old Jun 25, 2006 | 12:59 AM
  #45
Dr_jitsu's Avatar
Thanks Tony...love the MREV2 and spacer...can't wait to maximize their full potential
