oem exhaust or aftermarket?
Old Jun 26, 2006 | 01:56 PM
diablo1356's Avatar
performance wise which one is better?...oem single with HFC..or an after market single exhaust with HFC?
Old Jun 26, 2006 | 01:58 PM
IvoryGT's Avatar
true dual gives most hp gain. but translating to perfomance. I dont know with the added weight if it actually means going faster.
Old Jun 26, 2006 | 01:59 PM
diablo1356's Avatar
wont a single retain more torque plus with the added HFC be > than true dual?
Old Jun 26, 2006 | 02:35 PM
Skaterbasist's Avatar
Retired SuperMod
Singles will never give better performance over true dual
Plus, they look awful on G's
Old Jun 26, 2006 | 05:53 PM
truplay8's Avatar
THE BATMOBILE
dual
Old Jun 26, 2006 | 05:58 PM
FL-G35's Avatar
For performance Dual all the way
Old Jun 26, 2006 | 06:50 PM
Msedanman's Avatar
O.F. Administrator
+1 but the Borla TD is lighter by 20lbs than OEM.....
Loved mine on the Coupe.
C.
Old Jun 26, 2006 | 06:59 PM
gary c's Avatar
Just the facts.............?
At least two years ago one of the better magazines
had a install of the true-dual system from Stillen.
He advertises a 18 hp gain but this magazine put
the car on a dyno and it showed 14 RWHP...not bad!
A 14 hp gain is good for a bolt on, so the next thing
is sound.......Stillen...Borla...HKS...Magnaflow all
sound better than stock....your choice!
Old Jun 26, 2006 | 10:43 PM
diablo1356's Avatar
so my custom dual exhaust w/ magnaflow mufflers should put down more hp that the oem one??...isnt there a guy on here..i think its 99atlantic or something..who has the stock exhaust w/ hfc and all the breather mods..and he claims that he gets gains everywhere without the low end loss...this is what i want to achieve..i want more torque damnit!!...thanks for all the help guys...i love this forum
Old Jun 27, 2006 | 02:14 AM
truplay8's Avatar
THE BATMOBILE
custom is always risky........you have to have the right design to make the right power
Old Jun 27, 2006 | 10:55 AM
ISMSOLUTIONS's Avatar
Most of the duals out there loose low end and get it back at about 3K-4K - that's the problem.
The Fast Intentions Intimidator system looses it's low end at 2100 and gets it back 2200 - so no realization of loss of TQ in the band. When combined with our testpipes - the system gets 20HP and 18TQ - and that's on CA cars!
Check it out at www.fastintentions.com
But honestly - an exhaust can also only work as well and the rest of your mods and design of your goals with the rest of your car. So keep all of your goals in mind - FI or not? NA build...etc. Design it all together, so you don't cancel out one mod's advantages by putting another one in. People do it all the time.
Rick
Old Jun 27, 2006 | 04:10 PM
FL-G35's Avatar
Rick
That exhaust actually looks pretty good. I have a question though. I see after the cats there is a muffler almost acting like an "H" pipe. Is that correct or does it go straight through? If it is, what is the purpose, and why didnt you just continue straight pipes to the rear?
Old Jun 27, 2006 | 04:15 PM
That's a perforated x-pipe...for balancing the system. X pipes are more efficient in 6 bangers than H pipes - and they handle things like drone and pulse cancellation much better. In this case it is perforated, which adds to our tuning.
Rick
Old Jun 27, 2006 | 04:25 PM
FL-G35's Avatar
I see, i have the HKS exhaust and as much as i love the exhaust it definetely has a drone sound. It also doesn't have the "X" pipe either. Thanks for the info.
Old Jun 27, 2006 | 04:32 PM
No problem - keep in mind, just adding an X pipe to a system, or a perforated X, wont solve other system's issues. The system has to be designed to pass and/or cancel out the pulse. The key is the muffler(s) design in the end. Companies put in resonators and other 'masks' to cover their flaws in design or cheap mufflers, or extra thin pipe, that actually cause bad resignations and drone itself.
Personally I think the HKS is a very well built system. High quality welds, and pretty good fitment as well. I personally do not like the sound at all or the huge tips, but that is my taste as well.
Rick
