What high flow cats and Stock exhaust?
Old Jul 12, 2006 | 10:27 PM
MJ2315's Avatar
I've heard the Helix hfc with the stock exhaust and it sounded pretty mean...Anybody have this setup or any other suggestions/clips of another combination? I see those FI hfc in the group buy and they look tempting...Thanks in advance
Old Jul 12, 2006 | 11:59 PM
ballisticus's Avatar
Do you really need HFC? Those Fast Intentions resonated TestPipes look pretty phucking good. I have had the Kinetix TP for over a year and the power increase was immediate and indisputable. By all means, go resonated TP. You can always re-install your stock cats at smog check time.
Old Jul 13, 2006 | 02:38 AM
truplay8's Avatar
THE BATMOBILE
id go with crawford or fast intentions instead
Old Jul 13, 2006 | 11:22 AM
MJ2315's Avatar
Well the reason i wanted HF cats was because i wanted to avoid the rasp that everyone complains about with the test pipes, resonated or not...But by all means, ballisticus, if you can provide maybe a short vid or sound byte with the test pipe/stock combination that'd be sick.
Old Jul 13, 2006 | 12:29 PM
machavez702's Avatar
Make sure you hear a clip of a system with HF AND a stock cat-back. I recently went through this with my sedan, installed just test pipes with the stock cat-back. The stock cat-back could not handle the flow causing all kinds of vibrations. Most were from the stock exhaust's flex pipe ballooning, the threads were bouncing off of each other sounding horrible. I removed them and have since re-installed with a HF dual cat-back and all the rattles (and flex pipe) are gone.
Old Jul 13, 2006 | 01:35 PM
MJ2315's Avatar
Thanks Machavez, def something to consider...I was under the impression that the link from the Sticky on the top of the page had a Stock exhaust with HF cats clip, which made me indecisive upon what i want to do with my exhaust system.
Old Jul 13, 2006 | 02:38 PM
RebelinRI's Avatar
Also with test pipes you'll get that lovely smell of unburnt gas. Ah yes........ those were the days. If the smell doesn't bother you, go test pipes with a free flowing exhaust otherwise you'll get what Machavez and I had one time. All the rasp is due to the combo of HFC's/test pies to exhaust combo. Research and you'll do fine if you keep that in mind.
Old Jul 13, 2006 | 03:48 PM
MJ2315's Avatar
Thanks for the heads up guys. (btw the old Evo had a test pipe, im quite familiar with the smell) Looks like i may just have to buy FI true dual or HKS ti...
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
Daniel k.
Nov 3, 2015 09:52 AM
Th611
Oct 27, 2015 03:48 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
