pop charger cleaning
Old Aug 18, 2006 | 02:17 PM
LIUser's Avatar
i jusdt finished cleaning the jwt popcharger i got from gdude. i started with simple green diluted half with water but it didnt do that much, so i used the K & N recharger kit and it worked great. just wondering, is the popcharger supposed to be an off-white color when im done cleaning??? does it matter if some of hte grime isnt coming off on the edges of the pop charger??? has anyone used the k & n oil, does it give the popcharger a red tint? im just curious, i dont mind.
should finish installing my z-tube and pop-charger today, ill post pictures when im done =)
Old Aug 18, 2006 | 02:31 PM
Soopa G's Avatar
yes, if you use the K&N oil it will have a red tint, be sure not to over-oil it, too much is not good, you don't need much
Old Aug 18, 2006 | 03:28 PM
g35rcr's Avatar
did you let the filter soak in the cleaner before you rinsed it off?
Old Aug 18, 2006 | 03:35 PM
Jeff92se's Avatar
Red Card Crew
Yes. The cotton gauze is white when new but you can never get it all way white when cleaning. I wouldn't recommend using anything but the K&N cleaner. You DON'T want to deteriorate the guaze in any way by using the wrong cleaning agent.
Because it sounds like you are a newbie at this, I'll try to give some advice to the cleaning. Rinsing off the filter. In to out ONLY. And no strong streams of water. Tap pressure is plenty. Allow it to dry overnight if possible. When oiling the filter, spray it like paint. ONE pass for each section. Let it sit for a few min and then spritz in areas that aren't covered 100%. DO NOT OVER DO IT. Overoiling will coat the maf sensor with oil and then you have to clean the maf
Old Aug 18, 2006 | 03:36 PM
Sumlime311's Avatar
how exactly should you clean your popcharger? is it more then just using the k&n oil stuff or is there more you should do?
Old Aug 18, 2006 | 03:46 PM
Jeff92se's Avatar
Red Card Crew
Well reading the instructions helps.
Old Aug 18, 2006 | 03:53 PM
Sumlime311's Avatar
i know reading the instructions will help but it wont help me if I should use something else along with the k&n stuff. That is what I am asking
Old Aug 18, 2006 | 03:59 PM
Jeff92se's Avatar
Red Card Crew
This is also in the instructions.
Originally Posted by Jeff92se
. I wouldn't recommend using anything but the K&N cleaner. You DON'T want to deteriorate the guaze in any way by using the wrong cleaning agent. Because it sounds like you are a newbie at this, I'll try to give some advice to the cleaning. Rinsing off the filter. In to out ONLY. And no strong streams of water. Tap pressure is plenty. Allow it to dry overnight if possible. When oiling the filter, spray it like paint. ONE pass for each section. Let it sit for a few min and then spritz in areas that aren't covered 100%. DO NOT OVER DO IT. Overoiling will coat the maf sensor with oil and then you have to clean the maf
Old Aug 18, 2006 | 04:29 PM
g35rcr's Avatar
i've used simple green on my filters and never had a problem, the oldest filter has 80k miles on it and still looks new
Old Aug 18, 2006 | 10:48 PM
LIUser's Avatar
the k & n works very well, and yes, i did clean it correctly. oiling it tomorrow morning and putting it on, got the z-tube and heatshield on already,
thanks everyone
Old Aug 18, 2006 | 10:56 PM
sjc1789's Avatar
Florida G35 Club
i used the k&n last week when i cleaned my injen CAI... loved it
G35xdriver04
Nov 7, 2015 08:31 PM
NailBomb
Oct 28, 2015 07:53 AM
bigmike
Sep 17, 2015 01:58 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
