Poor Man's .10 Pop Charger!!
Old Sep 25, 2006 | 09:46 AM
  #31
Neal376's Avatar
lol,
I like it. It is interesting none the less haha.
I will try it one day just for kicks
Old Sep 25, 2006 | 04:06 PM
  #32
DHCrocks's Avatar
Originally Posted by aHero4Eternity
^^how did you remoive the lower resonator on the airbox? im assuming there was cutting involved? did you use a dremel?
no cutting required. you need to take out the air box to remove the resonator. it was a little difficult there's a bunch of bolts that are difficult to get to but it can be done if you got small hands. give yourself about 2 hours to do it, that should be more then enough time. I took it out from the top, but I think you can also get to it from below.
Old Sep 25, 2006 | 06:15 PM
  #33
DaveB's Avatar
Or you could simply remove the Power Duct cover, take the cap off of a plastic bottle, wrap some electrical tape around it to make the diameter larger, and use it to plug up the resonator opening
I've datalogged with the lower resonator plugged and I've noticed no increase in MAF voltage (more voltage means more air flow).
Also, once you've removed the sealed portions of the airbox (Power Duct, airbox entirely, etc), the resonator will not work. It relies on the natural pressurization effect of the OEM airbox to work.
Old Sep 25, 2006 | 10:48 PM
  #34
Calvin's Avatar
Overglorified Altima
^^wait, so are you saying since i removed the power duct the resonator does not work? therefore there is no point in me removing the resonator since it doesnt work anyway?
Old Sep 25, 2006 | 11:13 PM
  #35
G35m@'s Avatar
Installed the JWT POP tonight and here are my thoughts after running the .10 mod for 5-days.
.10 Mod = Better sound from intake and exhaust. By better for me I mean deeper - the exhaust has more growl and at WOT the engine just sings. IMO sounds like a meaner 350Z.
JWT - Quieter at all levels, but louder than stock. My seat-o-pants meter says there may be a couple horses more.
Installing the MD 5/16 this weekend and will drive with both set-ups and post my thoughts.
Old Sep 25, 2006 | 11:14 PM
  #36
GLuXuRy's Avatar
LMFAO... can you say ghetto :P
Old Oct 25, 2006 | 08:28 PM
  #37
dreamweaver's Avatar
hey couldnt help to notice why is your engine bay Grey? looks like you have dark colored G? or maybe im not seeing it right.... my 05 OB is black under the hood?
Old Oct 25, 2006 | 08:29 PM
  #38
your making me feel bad perhaps when i take out my Stillen cold air box ( cause i cant use it with the Vortech) i'll have to sell it to you cheap...
Old Oct 25, 2006 | 08:32 PM
  #39
O HELLA JDM's Avatar
not much to look at really, looks a little ghetto, but it only took a couple of minutes and a few cents to do. it seems to really seal off the opening well as you can see the impressions of where the hood is closing on the foam tape. The stock power duct also has a seal and this basically replicates that but enlarges the opening for fresh air to get in.
looks kinda ghetto but hay what ever works...
Old Oct 25, 2006 | 08:38 PM
  #40
DHCrocks's Avatar
yeah, why is it grey? mine is blue same as the car color but no clearcoat. maybe the car was repainted a different color.
Old Oct 26, 2006 | 11:58 AM
  #41
GreenGoblin's Avatar
The goblin resurrection
i think i will just save up for an intake
Old Oct 26, 2006 | 01:39 PM
  #42
Calvin's Avatar
^^good call lol
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
