Installed Z-Tube and K&N... FINALLY!!
Old Sep 23, 2006 | 04:42 PM
JDM_CPV35's Avatar
I finally installed my Z-Tube and K&N after almost a year of purchasing them. I must say that the butt-dyno was rather pleased. I had been complaining to the dealer about a 'loss of power', and they had said my car was fine, and that it was up to specs. After installing my Z-Tube and K&N, i found my OEM air filter was FILTHY! That explains the loss of power over the 1 year I have owned my car. I work in Downtown Miami, and as some of you may know, it is construction central over there and the air is thick with dust. My air filter had more black on the filtration element than the reddish color it is. Post-installation, was a different story, however. After I installed it, I took my G for a spin. The slightly sharper throttle response was definitely noticeable, and the sound was AMAZING! The car felt alive again, although not much more than when I first purchased it. My only question is: is the barely (and I mean barely) audible hissing noise normal at WOT? I know it is common no CAI, but I don't know if it is on a Z-Tube. Thanks!
Old Sep 23, 2006 | 05:47 PM
g35rcr's Avatar
you ought to try cleaing your maf too
Old Sep 24, 2006 | 08:35 PM
JDM_CPV35's Avatar
any DIY's posted on that?
Old Sep 24, 2006 | 10:46 PM
G35m@'s Avatar
someone posted something on this a few weeks back - run a seach and you will find it.
Old Sep 24, 2006 | 10:51 PM
Calvin's Avatar
Overglorified Altima
theres a few threads about cleaning the maf
Old Sep 24, 2006 | 10:57 PM
ozracer01's Avatar
Congrats on the new setup...I have the same, and I do suggest you clean the Maf Sensor...it evens out the idle and increases throttle response a little more(IMO). Cleaning it is very easy....you first buy CRC MAF cleaner from your local auto parts store...if thats not availiable then you can get some electronic parts cleaner. Then unplug the sensor's connector and use a phillips screwdriver to remove the 2 screws. Becareful removing the sensor...because if you drop it..you risk breaking the delicate elements inside. Spray it down liberally and when dry, put it back in.
Old Sep 25, 2006 | 11:11 AM
JDM_CPV35's Avatar
thanks guys will do that! i also had a hard time trying to reste the ecu... i must have tried at least 7 times and was unsuccessful... i also was in 90+ degree weather and sweating like a effin pig, and i was getting fed up so i decided to give up.
Old Sep 25, 2006 | 11:05 PM
Powashiftin's Avatar
Where did you buy your setup and how much?
Old Sep 26, 2006 | 02:36 PM
JDM_CPV35's Avatar
i bought my z-tube off of g35parts.com. the k&n at autozone.
Old Sep 26, 2006 | 04:22 PM
you bought a drop-in K&N?
Old Sep 27, 2006 | 12:56 PM
JDM_CPV35's Avatar
yep
Old Sep 27, 2006 | 01:17 PM
abcquackyxyz's Avatar
yeah there should be some hissing..its the tube since it isnt baffled like the stock tube
saskicker32
Aug 11, 2015 02:12 PM
khamlin
Aug 2, 2015 09:37 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Ninjay16
Jul 20, 2015 01:21 AM
