Intimidator Gains?
Old Oct 11, 2006 | 01:08 PM
ISMSOLUTIONS's Avatar
Originally Posted by Dr_jitsu
For the OP, if you just want an MREV and spacer, reseting the ECU should work (it did for me and I got noticeable gains). Add a dual exhaust w/ the stock cats and you should still be OK.
However, once you throw in the test pipes (which will give you a legit 10 HP...but only if you adjust your A/F ration) and then you must get eng. man. and a tune.
A lot of mods w/out management and tune will actually make your car slower.
+++111
Old Oct 11, 2006 | 03:34 PM
tekknikal's Avatar
hmmm ok, a few more questions...
1.
if i went:
spacer + exhaust + tp
i would get 20+whp, but would benefit from a tune
2.
if i went:
mrev2 + spacer + exhaust + tp
i should get a tune to even be safe, but a tune would also be necessary for gains as an untuned setup would probably not be as good as 1 (above).
3.
in the case of 1, i could get a TS reflash, tell them my mods, be safe and get good gains. in the case of 2, i could get a TS reflash, tell them my mods, correct the safety factor, and get better gains than i would have in 1.
4.
i could go UTEC instead of TS reflash, learn to tune (which sounds appealing if its doable for a newbie), and street tune my car to run safely and at certain AFRs for either 1 or 2 above.
5.
if i did 4, would i need a wideband gauge? i already have a computer (pic) so im not sure if i could use that with utec software to give myself a gauge? (maybe something like this?) i know obd2 doesnt do wideband afr, or at least i havent seen it so far...
6. from what ive read of utec so far id want to start with a safe base map and tune to hit a target a/f . then if i had a dyno i'd advance timing from there to max out my gains and step back a little once no more power is made. if i were doing a street tune, this timing step wouldnt be possible since i wouldnt know where the gains started to diminish....so would i just be stopping when i hit my target a/f points? if so, would that mean i wont be gaining much hp by tuning and am really doing this for safety?
Old Oct 11, 2006 | 04:01 PM
Dr_jitsu's Avatar
Beware of ricer math (as in option #1....spacer, tp, exhaust would not net u 20 whp...although u could easily get 25-30 w/ EMS and a tune).
It seems that you are capable of self tuning and since you don't have tuner options where you live, that is the way to go.
I would not even start modding my car if I was not planning on installing and aftermarket EMS and tuning. Therefore if you are committed to the UTEC, then you will benefit from mods.
Old Oct 11, 2006 | 04:06 PM
You will get more HP is every situation - once the ECU has been reset adn the car learns for about 50 miles.
You will get MORE HP if you tune. The better the tune, the more HP. A TS reflash is a bottom level tune, however there are other benefits with it as well, like rev limiter increase, etc.
With wideband and an AF - you can further fine tune things, though you will not be tuning timing maps. TS will put in a new timing map and well as the fuel maps.
With a UTEC, you or a tuner, have ultimate control over timing and fuel mixtures and can, with the aid of a dyno, give you the best result.
Rick
Old Mar 10, 2007 | 02:51 AM
redline624's Avatar
G35 Coupe 2007 with Rear Active Steering
Originally Posted by FastIntentions
The gains you see on our dyno charts are believable. If you have any questions, feel free to contact me @ 818-882-2788...Thanks, Tony
Do you know if this exhaust will work with Rear Active Steering 2007 Coupe 6MT
Old Mar 10, 2007 | 02:56 AM
Calvin's Avatar
Overglorified Altima
youd have to be local in order for FI to do some custom piping to make it work, from the way i understand it.
Old Mar 10, 2007 | 09:55 AM
FastIntentions's Avatar
LIke Hero said, you need to be local and I will custom build it to fit at no extra charge...Tony
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
magnetism80
Jan 27, 2016 12:57 PM
Usman Ali
Oct 4, 2015 08:23 PM
thechitoguy
Oct 1, 2015 05:25 PM
SePa_8310
Sep 16, 2015 04:32 AM
