Heat Insulation Wrap on Intake tube
Old Oct 16, 2006 | 11:07 AM
DaveB's Avatar
Originally Posted by Hydrazine
Here's an interesting note.
At least on the dyno, heat soak of the tube and MAF can indeed affect the power results.
What I have noticed is after an extended number of pulls on the dyno, the engine bay becomes quite hot even with an open hood and with all the fans turned on. A good part of the tube heating is from convective heat rising up from the the stock exhaust manifolds.
After a number of pulls, you can actually measure a significant increase in air temperature as seen by the MAF. This was observed through the OBDII scanner.
And I know the MAF is right up against the filter so there isn't much time for the air to become heated but there was no mistaking the results on the OBDII scanner. And of course, as measured air inlet temperature went up from ~70'F to 95'F, the HP went down. By 5-10 HP when the MAF indicated the air was hot.
Note that the coolant temperatures were still regulated to 190'F on all pulls and the fans were still in the same positions with the same settings. And the atmospheric temperatures were constant.
I've always found this to be a problem when trying to conduct controls on extended testing.
I still wonder how it all works because it seems like the air filter housing doesn't have enough surface area or residence time to heat the air that much... but it's clearly there.
It may be possible that the air itself is not actually hot, BUT the MAF sensor and its housing are thermally soaked and this may be prompting false measurements of the air temperature.
Keep in mind though that even if the air isn't actually hot, you can and will still lose power if the ECU "thinks" the air is hot. The ECU adjusts timing based on percieved air inlet temperatures.
So weather or not the air is actually heated (jury is out on this), the air inlet temperatures as measured by the MAF clearly show an increase. And as seen by the ECU, a percieved increase will result in a real world power loss.
I agree with your findings on the dyno, but under driving conditions, ambient air is flowing through engine bay. Sure, the air gets heated up because there is a big block of hot metal in a tight space, but the air movement greatly reduces the underhood temps, far more so than just running an engine with the hood up. As we all know, air movement is far more effect at cooling than just still cold air.
The shielded intake would be good at combating nearby extreme radient heat (ie manifolds, turbos) since that is the purpose of the material used. But when the intake is situated in an environment that is always hot (110-140 degrees), the tube (shielded or not), will heat soak. Don't forget that it is still connected to a hot manifold and engine.
Old Oct 16, 2006 | 11:22 AM
speedgeek's Avatar
Thumbs up
Hey Tony!
Just checking in, anything planned for the next big Motordyne mod. I’m lov’n the mrev.
Thanks!
Old Oct 17, 2006 | 01:51 AM
Hydrazine's Avatar
Originally Posted by speedgeek
Hey Tony!
Thanks!
A lot of projects will be in test fairly soon.
I'm opening up a new facility for the sole purpose of creating new mods. The Motordyne research and test facility.
Now I'll have all the time, room and equipment in one place need to design, machine, assemble and dyno test new mods. And I have a lot of unconventional and conventional projects in the works.
All the development and test should be as much fun as the mods themselves.
Old Oct 17, 2006 | 09:32 AM
vt_maverick's Avatar
Sounds good... any rough timelines on something new? I'm thinking about getting the MREV2 in a couple months, but I hate to go spend $500 only to want to replace it three months later.
Yeah, I know that info is probably proprietary and would kill sales for the next few months, but come on man, take one for the team...
Old Oct 17, 2006 | 10:03 PM
Hydrazine's Avatar
All of the new mods will be fully compatible with the all current mods. Each will work in a diferent part of the system.
Old Oct 18, 2006 | 04:02 PM
G35_TX's Avatar
Tests have proven that with a heat shield or wrap of some type around the airbox & intake tube it does cut down on the intake temps MOVING or not moving. DaveO and Tony have tested this. I also tested it with what testing equipment I have. I saw about a 40 degree drop on intake temps with the heat wrap under the same driving conditions.
Old Oct 18, 2006 | 04:09 PM
G35_TX's Avatar
Originally Posted by dovla
I don’t know how much difference does it make, but it definitely doesn’t hurt.
Picture below is from DaveB friend’s sedan, I think, and mine look similar.
That is actually my picture someone edited and posted up. I definitely do not mind people using my pictures but please ask.
yosip1115
Sep 9, 2015 03:30 PM
Albanian122
Engine - Exhaust
Sep 5, 2015 11:23 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
Julianpnce
Intake & Exhaust
Sep 1, 2015 07:41 PM
