HKS:About creamed myself
Old Nov 8, 2006 | 11:56 PM
Calvin's Avatar
Overglorified Altima
Originally Posted by LI-G35Driver
Is the exhaust all thats needed though or do you then need test pipes for the full effect. I am 33 and got the mod bug.. never ever thought I would at this age...
Chris
test pipes/high flow cats are always a plus i suggest fast intentions then again im biased
Old Nov 9, 2006 | 12:37 AM
X 350GT X's Avatar
hey hero,
if you then install test pipes and high flow cats are you replacing any part of the hks exhaust system. where does the hks start? im interested in getting one also, i dont mean to jack this thread.
thanks
Old Nov 9, 2006 | 12:43 AM
Hexxum001's Avatar
HKS is a true dual cat-back system. So if you get test pipes or hfc's the only thing you will be replacing is the stock cats.
Chris-HKS is pretty loud on it's own. If you drive normal, it has a nice deep growl to it. But when you punch it, it really roars. I wouldn't suggest test pipes unless you want it to be louder than that. I would suggest getting the exhaust first and letting it break in. It does get a little bit louder once it's broken in. If it's still not loud enough for you (I think it will be) then get test pipes.
Old Nov 9, 2006 | 12:48 AM
X 350GT X's Avatar
im a newb, but where does the test pipes go and i read it rids some restriction to your exhaust flow but dont really understand.
Old Nov 9, 2006 | 12:56 AM
Hexxum001's Avatar
The test pipes would replace your stock catalytic convertors. Test pipes help free up air flow for your exhaust cuz it is a straight through pipe. That's it. Nothing inside to restrict it.
Old Nov 9, 2006 | 12:58 AM
Calvin's Avatar
^^what he said
keep in mind if you get test pipes you better get used to the smell of unburnt gas!
Old Nov 9, 2006 | 12:59 AM
Calvin's Avatar
Originally Posted by X 350GT X
hey hero,
thanks
keep in mind you can only have one or the other. you cant have high flow cats and test pipes.
well...i guess technically you can have one high flow cat on one side and a test pipe on the other....lol
Old Nov 9, 2006 | 01:01 AM
X 350GT X's Avatar
so having a test pipe would elimate the catalytic converter, so that would be illegal in some states right. and HFC is a aftermarket cat with better flow? so you can either have a test pipe or HFC but not both rigth? TIA
Old Nov 9, 2006 | 01:03 AM
X 350GT X's Avatar
thanks a lot hero, sorry i didn't see this when i made my post above. i learned something new today.
Old Nov 9, 2006 | 01:04 AM
Calvin's Avatar
test pipes are cat deletes, yes. i believe it is a federal law that says you cant touch/modify/change your cats until like 80k or something. and you wont pass emissions (not in cali at least). our cars have 4 cats. fast intentions HFCs only have two and they are ...high flowing...lol
and technically, like i said, you can have one test pipe and one high flow cat
but i highly you suggest to get one or the other lol
Old Nov 9, 2006 | 01:06 AM
Calvin's Avatar
check out my review on the fi high flow cats
https://g35driver.com/forums/intake-exhaust/122425-fast-intentions-300-cell-metallic-high-flow-cats-pictures.html
also, there are resonated and non resonated test pipes. and some resonated ones are better than other resonated ones. i know. its confusing
Old Nov 9, 2006 | 01:18 AM
X 350GT X's Avatar
https://g35driver.com/forums/showthread.php?t=122425
thanks, i sure will.
Old Nov 9, 2006 | 01:55 AM
xx7sephiroth7xx's Avatar
G
^^ thanks for making this thread. exhaust = another topic i'm lacking in :P
Old Nov 9, 2006 | 02:07 AM
gary c's Avatar
What................?
hey hero,
thanks
You either have high flow cats or test pipes not both.
The HKS system is a cat-back system which refers
to the system after the cats........understand?
Old Nov 9, 2006 | 02:09 AM
  #30
Calvin's Avatar
hey. dont tell him what he can and cannot have. lol
let him be the first to have on test pipe and one high flow cat!
or not...lol
