Stillen w/ AEM or Apexi filter?
Old Dec 26, 2006 | 05:29 PM
erdog's Avatar
To those of you who have replaced your Stillen intake with a dry filter, did you keep the Stillen ring on?
From my research on the forum seems like the correct K&N replacement would be RC-2960 (http://www.knfilters.com/search/prod...x?Prod=RC-2960) which makes the correct AEM replacement to be 21-209DK (http://www.aempower.com/ViewTopic.aspx?TopicID=9) assuming the Stillen ring is used.
However I can't seem to figure out which Apexi filter would be the right one and if the Stillen ring is recommended to be used with the Apexi filter, since it has a dual funnel and probably a different channeling of air flow.
Anyone with any idea about the Apexi filter and whether or not the Stillen ring should be use?
Old Dec 27, 2006 | 02:08 AM
erdog's Avatar
Also, does changing out to a dry filter change the sound of the Stillen intake whistle. Mine makes a metallic grinding whistling noise between 2000 and 3000 rpms.
Old Dec 29, 2006 | 04:05 PM
erdog's Avatar
Anyone out there?
Old Dec 29, 2006 | 07:55 PM
fortified's Avatar
With the AEM dry filter, I retained the ring. It does not fit all the way down on the ring, but over half way, and appears to be a very tight fit even before cranking down the clamp.
Can't say I notice any difference in sound. But I sure like the idea of there being no oil in the filter.
Old Dec 31, 2006 | 01:32 AM
g35cas's Avatar
Don't have an answers for you, just wanted to say thanks for digging up the numbers for a stillen replacement filter.
Old Jul 25, 2007 | 01:41 AM
SpeedSTARs's Avatar
Just subscribing to this tread
Old Jul 25, 2007 | 02:42 AM
erdog's Avatar
Speaking of which, I finally changed out my stillen filter with the aem filter this past weekend. The ring didn't fit all the way like others have said but it wasn't a tight fit like others have said it would be. It fit perfect.
Old Jan 21, 2008 | 02:55 PM
bikinilust's Avatar
you might be able to bring it down more if you lubricate the outer portion of the ring with like WD40
Old Jan 24, 2008 | 01:53 AM
Beebo's Avatar
^+1
Old Jan 30, 2008 | 02:29 AM
SDGenius's Avatar
You should go w/the APEXi. GREAT flow, to find the right one jus mesure the Stillen one's dimmentions(opening, legnth, width at widest point). it should be pretty easy to find after that. Check on HorsepowerFreaks.com, they have filter sizes posted. yeah, bro custom mix is the way to go. i jus did somthin' similar w/the JWT PopCharger. I mounted a stainless-steel Blitz SUS filter to the JW velocity stack, sound's AMAZING... Seriously. well, here's a shot of my current intake set-up(still waitin' on my Cosworth plenum).
Old Apr 9, 2009 | 02:46 PM
WILLIE BEANS's Avatar
REGUARDING THE APEXI REPLACEMENT FILTER ONLY..
HOW WOULD WE KNOW WHAT SIZE TO GET THE APEXI AIR FILTER REPLACEMENT
THEY COME IN DIFFERENT SIZES ACCORDING TO HORSEPOWERFREAKS.COM
Universal 80MM Flange 500-AA03
Universal OD 140 ID 75 500-A024
Universal OD 160 ID 65 500-A023
Universal OD 160 ID 75 500-A022
Universal OD 160 ID 85 (Filter May Require use of apex adapter) 500-A021
Universal UNIVERSAL FILTER AND 70MM FLANGE 500-A027
Universal UNIVERSAL FILTER AND 75MM FLANGE 500-A026
DOES ANYONE KNOW WHAT SIZE WE USE ON OUR 1ST GEN 2003 G35 SEDAN ??
SUBSCRIBING FOR AN ANSWER ..IF ANYONE KNOWS IT ..
Old Jun 2, 2009 | 03:48 PM
bump for an answer ..
wondering if anyone has an answer as to what size flange we use on our filters...(jwt/stillen/injen) .. to use an apexi as a replacement ..
Old Jun 2, 2009 | 04:20 PM
SDGenius's Avatar
dang, old thread... you'd need a filter w/a 6" opening. don't think APEXi make's one of that size, sorry. you could always go w/the R2C repacment, like i did...
Old Jun 2, 2009 | 04:29 PM
haa . how funny i was just about to pm you .. thinking you had the apexi .
thnx bro ..
Picture Share
Feb 4, 2018 12:41 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
doorbell7942
Aug 12, 2004 01:29 AM
