View Poll Results: What should I get.
Borla
11.45%
MREV + 5/8 Spacer
12.98%
MREV + 5/16 Spacer
77
58.78%
I don't care what you do.
22
16.79%
Voters: 131. You may not vote on this poll
MREV + 5/8" Spacer or Exhaust
Old Apr 22, 2007 | 03:12 PM
  #31
OCG35's Avatar
Originally Posted by Nismo G
I already knew mostly everything you said, but i was never really sure because i never had the chance to "discuss" it with anyone. I was just going off of what i read here and there and then putting 2 and 2 together. I for some reason just always thought that the mrev2 was a modified" 5/16th spacer and a lower plenum "molded" togather, but i guess i was way off on that. Thanks for all the help! I might try to get a mrev2 to add to my 5/16th spacer now that i know it doesnt serve the same purpose. Toy around with it and my AFC II a little bit see what we can get out of it.
-Sean
you're welcome... good luck - let us know what you come up with.
Old Apr 22, 2007 | 03:30 PM
  #32
Nismo G's Avatar
see this is why im confused...
https://g35driver.com/forums/showthr...ghlight=mrev+2
Originally Posted by Hydrazine
Hi Guys,
I've recieved a million requests asking if the MREV can be installed on the 280 HP engine. Unfortunatly I had to turn them all down because the MREV is simply a spacer with a lower plenum from the 280 HP engine. ...So if you have the 280 HP engine, all you need to do is install a spacer and you automatially have a MREV.
According to this thread, if you have the non rev up motor and you add the 5/16th spacer you automatically have the same thing as the mrev minus the better machining for air flow...so all in all the 5/16 spacer is the same thing as the mrev except for the lower collecter that is machined for better air flow...
-sean??? im confused now haha
Old Apr 22, 2007 | 04:03 PM
  #33
Jeff92se's Avatar
Red Card Crew
MREV = non-rev up lower
MREV+ = machined non-rev up lower
Old Apr 22, 2007 | 04:16 PM
  #34
Nismo G's Avatar
Yes, I’m aware of that (that wasn’t a sarcastic voice either), but what i was trying to ask earlier is isn’t the mrev the same thing as the non revup lower plenum and a 5/16th spacer hypothetically speaking. So the example that i was trying to give is that if you were to weld or mold a 5/16th spacer to a OEM lower plenum then essentially you would have what is called the mrev...right?
To me thats what it sounds like tony was trying to say in my last post...
-Sean
Old Apr 22, 2007 | 04:21 PM
  #35
Jeff92se's Avatar
Red Card Crew
-Sean
Tony is exactly correct.
Old Apr 22, 2007 | 04:27 PM
  #36
Nismo G's Avatar
Jeff read OCG35's post on page 2 and mine..doesn't he say that the mrev 2 and the 5/16 are completely different things? I mean yes they are, but essentially they are not since the OEM lower plenum and 5/16th spacer are all in one.
So what i was asking is since i already have the non-revup motor and a 5/16 spacer would it be any use to replace the oem lower plenum with the mrev2 since all i would be doing another 5/16 spacer basically? Hypothetically speaking wouldn't it do the same thing as just adding -2- 5/16 spacers to my OEM plenum? (minus the machining of course_
-Sean
Old Apr 22, 2007 | 04:37 PM
  #37
Jeff92se's Avatar
Red Card Crew
MREV in any form doesn't = 5/16" spacer. Not quite sure where you are getting this
Benefical? From what I read yes.
No.
No. Spacers does not = MREV2 IMHO anyway.
Old Apr 22, 2007 | 04:42 PM
  #38
Nismo G's Avatar
No.
Hi Guys,
Isnt that what he is implying here though...? That if you have an OEM plenum with a 5/16 spacer it is already a mrev though...
-Sean
Old Apr 22, 2007 | 04:48 PM
  #39
OCG35's Avatar
-Sean
You are confusing MREV, MREV+ and MREV2... I addressed each.
What is the date of Tony's post you are quoting?... I suspect it was before he even started doing the MREV2
Original MREV was the nonrevup lower collector for the revup motors... I have stated this MANY times today.
Old Apr 22, 2007 | 04:52 PM
  #40
Nismo G's Avatar
Ok i thought i read that the only thing that changed between all of them was the machining for air flow...isnt the mrev 2 the same thing as the mrev except the fact that the inlets are redesigned for better air flow, but the other outside molding stays the same...
EDIT: i really am sorry about all this i have heard so many things then i read something else and it makes everything that i had read fall apart.
-sean
Old Apr 22, 2007 | 04:55 PM
  #41
OCG35's Avatar
-sean
yes, MREV2 is a modified MREV - modified by machining the lower collector for better airflow... as it pertains to your needs read the post I made about the benefits of each...
Old Apr 22, 2007 | 05:00 PM
  #42
Nismo G's Avatar
Well you really havn't stated. What are ALL of the differences between the mrev and mrev2...
  #43
OCG35's Avatar
-sean
Don’t be sorry - you are asking the right questions, you just don’t seem to be understanding the answer I keep telling you... ad far as what you have read previously - there is a lot of quack talk out here about what it actually is... I've seen it a million times. Some people post definitions that just baffle me.
Honestly, you have such a continuous flow of questions and seem to be a little reluctant to latch on to an explanation; I highly suggest you give Tony a call directly. He is a great guy, obviously knows more about it than anyone – and has some of the best customer service I have experienced in any industry ever. He will help you understand and give you answers you can count on.
Old Apr 22, 2007 | 05:01 PM
  #44
Nismo G's Avatar
yes it machines the lower collector, but as far as the outside mold its still going to provide a 5/16 space over the OEM plenum just as the mrev did correct?
Old Apr 22, 2007 | 05:03 PM
  #45
OCG35's Avatar
spacer has always been a seperate option... never a required part of the MREV line. Yes, a spacer fits over all of them the same.
