View Poll Results: What should I get.
Borla
11.45%
MREV + 5/8 Spacer
12.98%
MREV + 5/16 Spacer
77
58.78%
I don't care what you do.
22
16.79%
Voters: 131. You may not vote on this poll
MREV + 5/8" Spacer or Exhaust
Originally Posted by OCG35
again, nothing is added to the lower collector to make it an MREV2... only material taken away. So if you start from scratch with your OEM non-revup lower collector nothing more than taking away (not adding) of material would be done to create the MREV2.
MODS, please move this to intake, exhaust where it belongs... this might get better explanation there. So far only misconceptions here...
I PMed tony hopefully he will understand my question.
-Sean
Your request to remove and relocate this said thread to the appropriate section is noted and done. See ya on the other side.
Previously. MREV (before any MREV + or 2 was available) was a PACKAGE. That package = MREV (non rev up lower manifold) PLUS a 5/16" spacer. Not bonded, welded, attached, glued, etc. etc. etc..
I don't know how to say it any easier than that.
Originally Posted by Nismo G
I dont think by moving it we are going to gain or loose any information. Its just simply going to be in another area of the forum. Now tony said that the original MREV was simply a 5/16 spacer and a OEM non-revup plenum, essentially. Now use your imagination and imagine if you could bond the 5/16 spacer to the OEM plenum. You would then have what looks identical to the MREV. Now the MREV2 is machined differently. By it being machined differently are we talking about just the air inlets them selves, they are redesigned so more air can be flowed through them. Or is even the out part of the plenum redesigned...idk
-Sean
-Sean
Originally Posted by Nickk6
I've been itchin to mod my car some more and been planning on getting a Borla exhaust, but for the money right now I am not sure if I rather wait for the exhaust and get the spacer and mrev now.
Can I use the MREV with the 5/8" skunk 2 plenum spacer. This whole set up will run around 575 + shipping from everythingg35 where as a exhaust would cost about $775+ shipping.
Originally Posted by b00stedjustin
wonderfull Jeff. I pointed out an actual member's results and now you pull up some non descript dynoresults? I give up with you Vette Fan Boy.
I met a guy at the skyline drive meet with the mrev and spacer installed but with before and after tyno runs, which showed absolutely no change lol. From what I understand you need to run a utec for that mod to really come to life (unlike a simple exhaust install).
All runs performed on ScHel's fully stock 287 hp 350z
Originally Posted by Hydrazine
Hi Guys,
I've recieved a million requests asking if the MREV can be installed on the 280 HP engine. Unfortunatly I had to turn them all down because the MREV is simply a spacer with a lower plenum from the 280 HP engine. ...So if you have the 280 HP engine, all you need to do is install a spacer and you automatially have a MREV.
-Sean
For the reading impaired.
Jeff, i was trying to refer to what tony said in this post.
Maybe i'm being retarded and just looking at it to critically, but what is being said here then? What does he mean by "All you need to do is install a spacer and you automatically have a MREV"?
-Sean
-Sean
Why would Tony try sell the mrev lower manifold to those that ALREADY have it?
Justin. Are you ACTUALLY saying that the spacer and such don't work w/o an ecu tune??
Do you KNOW how many dyno tests that one dyno graph represents??? EXACTLY how is Tony's dynos LESS real world than your example??
Halarious to say the least.
Here's the real kicker:
2003 DG coupe. HKS Hi-Power Exhaust (installing friday), Motordyne 5/16" plenum spacer, Nismo CAI (in the mail), skyline and 350gt emblems (in the mail).
You're an idiot. You can't compare real world results to what some company puts out. The only way you can counter this is if you have before and after results from a private party. God fanboy, you really can't formulize a coherent argument can you?
Because if you DON'T have a rev up motor, you already have the mrev lower intake manifold. Thus only needing to add a spacer to complete that package.
Umm i have no idea why tony would do that, i never said he was trying to do that...i was just confused as to what he was implying. Why do people try to sell fake cars online? I’m not accusing tony of anything as i have never heard a bad word about him I’m just re implying your question.
As for what tony said in his "statement" i was confused as i thought that the mrev was an option to get a new lower manifold with a 5/16 spacer already molded to it. Thats what i thought he was saying. I didn’t know the mrev was the same exact thing as the non-revup lower plenum...thats all.
-Sean
Nismo. The question was rhetorical
Thank the lord we finally got that cleared up.
-Sean
-Sean
P.S. it's hilarious not halarious moron.
