should i dyno???
Old Jan 14, 2007 | 08:02 PM
eemon10's Avatar
should i dyno???
ok so im getting the hks exhaust,5/16 plenum spacer and mrev2...i havent decided if i should get testpipes or hfc...ne ways after all these mods do i have to get dynoed or wat?...
and should i go with tp's or hfc?
Old Jan 14, 2007 | 08:17 PM
Calvin's Avatar
Overglorified Altima
you should dyno your car before doing ANY mods.
then, if youd like, you can dyno after each mod to see how much each mod helped or when youre done to see where youre at which can also be used to help tune you.
Old Jan 14, 2007 | 08:21 PM
GWord256's Avatar
On top of that you should post all Dynos so everyone else can see what helping and whats not.
Old Jan 14, 2007 | 08:22 PM
eemon10's Avatar
thanx but how much is a dyno...but i think wat i meant to ask was should i get a tune after those mods...if so how much is a tune?
Old Jan 14, 2007 | 10:59 PM
speedgeek's Avatar
+1
Dyno before mods so you can get a baseline, then go back to the same shop after modding. Each dyno is different, so you wanna stick with the same shop.
I'm from LI,NY and went to these guys, 65 bucks 3 pulls
http://pampenamotorsports.com/tuning.html
Old Jan 14, 2007 | 11:22 PM
ISMSOLUTIONS's Avatar
Dyno before for baseline....
Then dyno after to see the improvement/loss...yes loss happens!
Also - get an A/F piggy back..if your not going major NA or FI, then just get the Apexi SAFCII - about $300 and it'll make your after dyno/tune well worth it!
Rick
Old Jan 15, 2007 | 12:55 PM
eemon10's Avatar
how much is a tune?
Old Jan 15, 2007 | 12:57 PM
Originally Posted by eemon10
how much is a tune?
Depends on your piggy back solution and the shop. Anywhere from $200 - $500??? I've had tuning sessions that cost more than that...
Rick
seagrasser
May 3, 2022 09:43 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
