sound coming from the exhaust
Old Jan 15, 2007 | 03:35 AM
Kensi's Avatar
Just lately, whenever i start my car or just rev it up to 3000 in between it has this werid vibration noise.. i know it because i never heard it b4 and it really sounds annoying, it sounds like its coming from the exhaust inside itself, sound like theres something inside but not really. i dont really know what is wrong but im guessing the exhaust is somewhat loose? i really dont know..
Old Jan 15, 2007 | 03:43 AM
Slyding_G35_03's Avatar
i think its probobly the exhaust flex. not too sure about it to unless u provide a sound clip. do u have a aftermaket exhaust?
1. might be the exhaust flex.
2. exhaust hanger.
3. someone sticked something inside. :-p
Old Jan 15, 2007 | 04:39 AM
888's Avatar
888
did u run over anything or hit anything
your exhaust pipe could be bent.
Old Jan 15, 2007 | 06:37 PM
Kensi's Avatar
hmm ill post a sound clip asap!
Old Jan 16, 2007 | 09:58 AM
ISMSOLUTIONS's Avatar
What exhaust do you have? CATS, TP's?
Could be a flange leaking...
Rick
Old Jan 16, 2007 | 11:22 AM
Calvin's Avatar
Overglorified Altima
Rick
he's bone stock
Old Jan 16, 2007 | 11:50 AM
JOKER's Avatar
CLUB MODERATOR
I got a same thing on my coupe. It's rattles, almost as something loose in there.
Old Jan 16, 2007 | 12:03 PM
gary c's Avatar
He show that his G is "Bone Stock"
Noises.........take it back to the dealership if you have any warrinty left or
if you don't run it by a reliable muffler shop and ask them to check it out.
You've got to have it in the air, running to find the rattle.....like on a hoist.
Old Jan 16, 2007 | 12:34 PM
There is a very common problem with CATS and TP's and aftermarket exhaust combinations that make this sound. This is the first I have heard about it on a stock system.
The issue, usually, is that the engine firring order can be hear from about 2400-3600 or so RPM, at different points, as the exhaust is freer flowing, and you can generally hear more sound..even in the pipes themselves.
If this is happening to a stock car, I can only think that the CATS or the factory Y pipe is having an issue at the flex joints...which is also very common.
Rick
Old Jan 17, 2007 | 01:09 AM
Kensi's Avatar
so bascially ill just take it to the dealership and tell them something is wrong with my exhaust and that there is a different sound being generated then before?
Old Jan 17, 2007 | 02:19 PM
For a stock system....that's where I would go...
TWASkyliner
Feb 8, 2020 08:00 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
atk08
Jul 30, 2015 03:12 PM
