y-pipe
Originally Posted by G35_TX
Ahh again the clueless one posts. No mods work on the G35 per him.
Originally Posted by G35m@
I sold my 06 Sedan mid-pipe to a guy who swaped out his 03 OEM and he said it sounds better and it def weighs a lot less. I swaped out for a Coupe Middy.....we are never satisfied
The sound is perfect. I had the coupe middy last year and it just didn't sound right when teamed with the 03 muffler (slightly different than the 05+ muffler). The weight difference is about 17lbs.
Originally Posted by gtbigup01
Do most of you guys with the plenum spacer have the regular one or the ISO Thermal on? I just went to the market place and search one of the vendors site and it's $290 for the Thermal, does that sound about right? If not please direct me to a more price friendly vendor (lol).
1) No matter what kind of thermal barrier you have between the intake manifold and block, once the underhood temps get hot for extended periods, the intake manifold will heat soak.
2) I've never seen any measurable difference in the 1/4 mile ET/MPH between a scalding hot motor and a cool motor.
3) The lower manifold bolts are pretty soft and snap easily. It's one headache to choose to avoid.
Originally Posted by aHero4Eternity
what advantages does an 05+ sedan midpipe have over the coupe midpipe? just curious (really, i am. lol)
1) The coupe midpipe only has one hanger near the differential where as the sedan midpipe has two. The additional hanger reduces NVH. The coupe doesn't need the hanger because of the different design of the coupe muffler.
2) Sound. The coupe midpipe is designed to compliment a cross-flow style muffler. The sedan muffler is a variable capacity straight-thru unit.
The 05+ sedan midpipe can be purchased from everythingg35.com for about $190 shipped or used for $80-120.
Ahh again the clueless one posts. No mods work on the G35 per him.It's amazing what your knowledge of the G could be if you actually owned one longer than a few months....or even had one currently for that matter.
I guess we should give it a few more months when you can't get your check engine light issue solved on your TL, trade for a new G, and then you can flush thousands more bucks down your personal financial black hole on G-mods just because you have a beef with DaveB.
I owned a G35 for 2 yrs. Even if it was two different model years it was 2 years.
I have more knowledge on the G35 than Jeff or DaveB combined do. I tested products for vendors and Sport Z Magazine.
Even the ISO SPACER works and others proved it in tests so did I. I had a spreadsheet that showed the differences on a heat soaked car idling and after driving. The differences were night and day. But DaveB says oh there isn't a difference. But he has yet to own that product.
Sad part is, I am not the only person that has a beef with DaveB. Many on this site do.
There are many other mods much better for gains than a Y. I haven't really seen anything definate nor have I really read anything conclusive that the Y really does do anything but make noise.
Headers will make some power but create noise.
Your best bet is probably a set of hi flow cats.
Originally Posted by Rafal
i just purchased a 03 g35 sedan and i've been researching and reading forums to see what mods i can perform while still keeping the stock feel. I was thinking perhaps purchasing a y-pipe and bolt it on to the stock exhaust if possible. Maybe headers and a y-pipe but definitely keeping the rest of the exhaust stock. i was wandering what diameter the stock exhaust is? thanks in advance.
Originally Posted by Jeff92se
Test monkey /= knowledge
Love to look at them. Really
I will look for them tonight. I think they are on my backup hard drive since I had that system crash I was able to back up some stuff but not all.
Jeff here is the html of the info I did a while back. Can't get it uploaded to my site for some reason at the moment so I zipped it and attached it.
percent cooler with thermal kit
Upper plenum 11%
Lower plenum 3%
Throttle body 12%
Intake tube 5%
The results didn't surprise then when I saw the numbers nearly 2 years ago and they don't surprise me now. The thermal kit does reduce temps and I've never debated that it doesn't work, but I do not believe this kit works to the degree people think it does (ie over a 30-50% reduction in temp). Overall, you're looking at a reduction of temp on a upper 60 degree/lower 70 degree day of around 10% or so. For me, it doesn't seem worth the money or effort. I'm sure others would see it a different way. And for my car, I see no measurable difference between running on a completely heat soaked intake manifold and a stone cold intake manifold. What influences my car's performance is the density altitude of the day. DA alone has been responsible for improving my ET/MPH by nearly .2 and 1mph.
i hate to interrupt this debate, but what would you guys recommend as a mild upgrade. i don't want a full exhaust and i have a k&N drop in filter. Should i get a CAI or a short ram? I just need someone to throw me a bone. I just got rid of my VW gti so i know what to do for a turbo car and where to go since i've owned it for 4 years but with this new car i'm completely lost. Perhaps a chip or something along those lines. nothing too aggressive. thanks in advance
