K&N Replacement Air Filter 33-20312
Old Mar 22, 2007 | 08:45 PM
AlcatrazT2's Avatar
I just hit 15,300 and purchased the K&N Air Filter. I know this is a drop-in, but to install it, do I need any tools?
I tried to remove the four clips but the thing wouldn't budge so when I get home after work - I guess I have to take the tools out. Any suggestions?
Thanks in advance.
-George
Old Mar 22, 2007 | 09:22 PM
sloppymax's Avatar
there is a 10mm bolt that mounts the tube right next to the manifold remove that and unbolt the clamp from the throttle body either using a flat headed screwdriver or a 8mm. undo the clips again and it will give you enough room to replace the filter. attach tube & clamp back to tb and bolt the 10mm back to its mounting point and call it a night.
Old Mar 22, 2007 | 10:01 PM
Bigd2k6's Avatar
took me about 20 mins. the intake tube can seem a little rigid at first but it's easy.
Old Mar 22, 2007 | 10:42 PM
ttrank's Avatar
Grocery getter
Search is your friend.
Old Mar 23, 2007 | 09:47 AM
cato's Avatar
SouthernComfort Moderator
Thanks in advance.
-George
I did a DIY on air filter replacement back in 2003. Look in the DIY forum. There are several ways to do it. Some more difficult than necessary. You may want to do like I did. I asked the mechanic at Infiniti how to change the air filter. It is quite easy.
It looks like my DIY was deleted.
Here is the way Infiniti told me to do it.
1) remove the front air scoop above the radiator by taking a small flat head screwdriver and popping up the plastic rivets, remove the rivets and save for later use.
2) remove the 10mm bolt securing the air box to the frame.
3) grab the power duct with your hand and pull upward. It pulls the air box out of two holes below. Take a flash light and look below the airbox. You will see two protrusions at the bottom ot the airbox and also see two holes below that they fit into.
4) unclip the clamps, open the box and replace filter.
Installation is reverse of the above.
After a few time doing it this way, you can change the filter in less than 1 minute.
Old Mar 23, 2007 | 11:22 AM
Calvin's Avatar
Overglorified Altima
http://www.infinitihelp.com/Ownershi...G35/AirG35.htm
Old Mar 23, 2007 | 02:10 PM
cato's Avatar
Originally Posted by aHero4Eternity
This is the difficult method. I described the easy way. Do whichever way suits you.
Old Mar 23, 2007 | 02:33 PM
BadBoy06's Avatar
lower clips can be a PITA
Old Mar 23, 2007 | 03:14 PM
IP05G35's Avatar
You don't need to remove the air scoop above the radiator!
Old Mar 26, 2007 | 01:14 AM
AlcatrazT2's Avatar
I basically did the following method:
When rev'ing up the engine (3,500-4,000 RPM) I hear a slight whistle sound...I know this is common but I do not have a z-tube. Is this common for people that just drop-in?
Old Mar 26, 2007 | 02:37 AM
nghiars's Avatar
im surprised u didnt ask on socal george.. i noticed it when i put in the pop charger too... but i dont think it has anyting to do with the z tube.. just more air coming in... ppo said to do an ecu reset after but is it really necessary for after the k&n or after the pop charger install?
Old Mar 26, 2007 | 09:45 AM
RebelinRI's Avatar
I agree with Cato, but if that doesn't work just get a big hammer. That sucker will just fly right off! Putting it back on................. well.
Old Mar 26, 2007 | 11:33 PM
AlcatrazT2's Avatar
I doubt after a K&N... I mean, it's just a filter lol...
Old Mar 30, 2012 | 01:18 AM
mark4healing's Avatar
I have looked throughout the site for anyone familiar with BLITZ advance power filter for the G35... anyone familiarized with this? any links I could look into for reviews? I'll appreciate the help
Old Mar 30, 2012 | 11:26 AM
mpugeda's Avatar
^ search.
