running rich?
Old Apr 6, 2007 | 09:05 PM
seung012's Avatar
running rich?
sup everyone. i have a 2003 black g35 coupe. i have the JWT intake, crawford plenum, test pipes, and apexi n-1 exhaust. the car runs fine however, ever since i installed the plenum, the car seems to run rich. when i rev the motor and or just let it idle, i can smell gas fumes from the exhaust... anyone have any theores???? thanks everyone!!
Old Apr 7, 2007 | 01:30 AM
888's Avatar
888
i had the same thing happen when i install the HKS exhasut..
i get backfire too.
Old Apr 9, 2007 | 09:12 PM
20004DSC's Avatar
I had the samething happen after I installed test pipes and it got worse after I put on the Kinetix plenum. It has been like that for almost 2 years and I haven't seen any negitive effects.
Brian
Old Apr 9, 2007 | 09:16 PM
GreenGoblin's Avatar
The goblin resurrection
could always get it tuned to the correct a/f ratio
Old Apr 9, 2007 | 09:24 PM
20004DSC's Avatar
Can't tune a stock ECU, I'm waiting for the Cobb Tuning setup to become available. Should be sometime this summer.
Brian
Old Apr 10, 2007 | 04:12 PM
Jeff92se's Avatar
Red Card Crew
It's not running rich. It's because you don't have the pre-cats on anymore and it's not cleaning up the exhaust as much as before. If anything, you would be running lean.
Old Apr 10, 2007 | 04:21 PM
b00stedjustin's Avatar
I wouldn't say you are running rich. If anything you would be running lean. Your car is just breathing better, which is why you are getting the different smell. You can definitely smell the difference when you are running your car in your garage with just a CAI.
Old Apr 10, 2007 | 04:22 PM
Jeff92se's Avatar
Red Card Crew
Haha. I think you spent too much time doing that
+1. Your car is just breathing better, which is why you are getting the different smell. You can definitely smell the difference when you are running your car in your garage with just a CAI.
Old Apr 10, 2007 | 04:25 PM
Jeff92se's Avatar
Red Card Crew
1) The car won't breath any "better" with just the cai.
2) The reason the smell is diff is the elimation of the precats. Not because of any breathing improvents (although the test pipes WOULD actually do this). If you put test pipes in that had a restrictor (so it would "breath" the same as before), you would still get that diff smell.
Thebaws11
Jul 2, 2021 11:36 AM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
n2fooz
Sep 4, 2015 07:46 PM
