Crack in plenum spacer
Old Apr 9, 2007 | 08:45 PM
waijai's Avatar
i.love.gold
Do you guys think this will cause a leak? Its one of the smaller holes in the spacer. I just bought this used FYI. The gasket it came w/ doesn't cover that particular hole.
Old Apr 9, 2007 | 08:51 PM
Nismo G's Avatar
It will not cause a leak as long as it the inside isn't exposed to the outside. If that is brand new i would send it back though. If you torqued it to much and it cracked then i guess you are SOL, but it shouldn't cause a problem as long as the inside isnt exposed to the outside.
Old Apr 9, 2007 | 08:52 PM
izmir41500's Avatar
G35driver Addict
oh crap that sucks. looks like someone overtightened the bolt. i wouldn't risk it, get your money back.
Old Apr 9, 2007 | 09:07 PM
rcdash's Avatar
if the mating surfaces are smooth and the crack does not communicate between the inside to outside, then I'd think you could seal it back up pretty easily with some type of metal repair compound... (oh and don't try to put a bolt through there again)
Old Apr 9, 2007 | 09:30 PM
Andy2434's Avatar
Tough call . . . But for what it's worth . . . I would not risk installing it. My concern would be that a small piece could break loose and potentially find its way into the intake track . . . Just a thought.
Old Apr 9, 2007 | 09:39 PM
waijai's Avatar
i.love.gold
It's the Skunk2 plenum spacer, so metal repair won't work. Maybe some JB Weld?
Old Apr 9, 2007 | 09:40 PM
GLuXuRy's Avatar
JB WELD FTW ... naw talk to the manufacture see what they say
Old Apr 9, 2007 | 09:45 PM
BadBoy06's Avatar
O o..used = trouble with getting your $$$ back.
May work as others have said..inside/outside contact
Old Apr 9, 2007 | 11:36 PM
waijai's Avatar
i.love.gold
Just sent Skunk2 a message on their website for tech support. We'll see what they say.
Old Apr 10, 2007 | 12:17 AM
richie's Avatar
isn't that the hole that holds the bolt for the engine cover (thats why your gasket doesn't have a hole there) ?
EDIT: my bad, that hole has nothing to do with the engine cover =P
Old Apr 10, 2007 | 01:54 AM
RebelinRI's Avatar
Good eye(s). 6 vets missed that! Good thing the NEWB caught it!!! LOL Nice one Richie
Old Apr 10, 2007 | 02:10 AM
Andy2434's Avatar
The rear of the engine cover attaches to the rear of the upper plenum/collector at 2 locations. However, those 2 said bolt locations are some 2+ inches above where the spacer and plenum meet.
Old Apr 10, 2007 | 02:18 AM
RebelinRI's Avatar
and has nothing to do with holding the two halfs together.
Old Apr 10, 2007 | 02:45 AM
accordfreak's Avatar
just weld the crack shut. then sand it smooth again. no biggie. few bucks
Andy2434's Avatar
What I was trying to say in a light hearted way is . . . The said spacer location has no direct relationship with the engine cover mounting configuration . . . Ummm . . . You need to figure the rest of the story.
Edit: Hmmm . . . Or did I misunderstand your last comment? Oh well . . . Regardless, I trust that the OP gets his issue resolve soon.
