Does RASP sound like a duck being strangled?
Old Apr 25, 2007 | 08:56 PM
speedgeek's Avatar
at about 3300 rpm? I just got Strup headers and FI Metalic cats with a stock exhaust and I'm getting this duck squeezing exhaust note between 3300 - 4000 rpm.
Old Apr 25, 2007 | 09:11 PM
BadBoy06's Avatar
I would make sure everything is tighten up to
Old Apr 25, 2007 | 09:32 PM
speedgeek's Avatar
Thanks. Yeah, just got back from the shop, everything’s tight. I've been searching, I think this is rasp
Now I'm trying to look for an inexpensive exhaust solution (other than going back to stock) from the ypipe --> back
I'm hearing a lot about magnaflow resonated xpipes, but I'm not sure that would integrate with the stock system
Old Apr 26, 2007 | 10:46 AM
jasonlee4180's Avatar
I've never strangled a duck but i've always defined rasp to sound like a bunch of rattling BB's in a tin can. Very metallic and tin sounding.
I'd imagine your duck sound to be something metal rubbing against metal. Could something be rubbing underneath?
Old Apr 26, 2007 | 11:17 AM
Skaterbasist's Avatar
Retired SuperMod
LMAO at the duck reference
Rasp would sound like... damn, it's serious so hard to explain, yet easy to hear.
The only good reference I can make is; Just imagine squeasing your throat, and trying to scream. Just add a metallic tone to it, and you have rasp.
Did this help?
Old Apr 26, 2007 | 11:33 AM
Nismo G's Avatar
if you have ever heard an m3 give the car a little bit of gas that is what rasp is...search youtube for m3 exhaust, im sure you will find something.
-Sean
Old Apr 26, 2007 | 11:49 AM
RebelinRI's Avatar
I had rasp before (not this car) and I wanted to strangle a duck too! Probably too much flow for the stock system. You'll get a tinny sound from the headers but rasp sucks!!!! I would look at finishing the rest of the exhaust off. Why not give FI the rest of the way back??? "X" pipes give you that gurggling sound. Sorry not a fan of, even on V8's. Good luck with killing the "Duck".
Old Apr 26, 2007 | 12:22 PM
speedgeek's Avatar
Thanks folks. Yeah, it's rasp.
At some point i'll finish up the rest of the exhaust.
quack quack
Old Apr 26, 2007 | 12:37 PM
diablo1356's Avatar
try wrapping the cats (not the actual cat portion) back and make sure you cover the flex joints. (with header wrap--found in almost all automotive parts stores) there have been numerous threads bout this same problem and this seems to help. does the sound kinda go away after the car warms up? i just got kinetix cats installed and i have intake, spacer, topspeed headers, and now the cats on the stock cat back and i get the same sound but it does go away after the car warms up. search "rattle, exhaust" or "HFC, rattle" something along the lines of that.
Old Apr 26, 2007 | 12:45 PM
speedgeek's Avatar
Hey Diablo,
Thanks. Yes, if does get better once the car warms up. So i should buy some exhaust wrap and wrap from the cats back, to as far as I can go. and also use exhaust wrap on the flex section.
Thanks for the info.
Old Apr 26, 2007 | 12:46 PM
BracketRacerSteve's Avatar
I got your duck rasp right here
http://www.frogstar.com/wav/displayw...il=duckjob.wav
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
