service engine soon light after changing air filter
Old Apr 30, 2007 | 08:15 AM
BBart's Avatar
I had a tough time changing my air filter yesterday. I know I forgot to re-tighten the bolts on the air hose. Do you guys think that is the problem or did I mess up my air flow sensor? Thank you in advance
Old Apr 30, 2007 | 09:34 AM
sdnpaul5at's Avatar
Just reset your ecu, damn your original filter must of been filthy, your just getting more air into the engine and the ecu needs to re-adjust.
Old Apr 30, 2007 | 09:47 AM
BBart's Avatar
Thanks man. I will try that, hopefully I didn't mess up the MAS while I was pushing and pulling trying to get the damn thing out. It was pretty dirty. It had been 15K since the last time I changed it. If it wasn't such a PITA I would replace it more often.
Old Apr 30, 2007 | 10:45 AM
bkd's Avatar
bkd
If you didn't tighten the clamp on the intake hose before running the car, you probably just had an intake leak after the MAS. That would cause a code. If you clear it and it doesn't return then you are ok.
Old Apr 30, 2007 | 03:45 PM
ttrank's Avatar
Grocery getter
Let us know if a reset does not cure the SES.
Old Apr 30, 2007 | 05:57 PM
BBart's Avatar
I tightened down the clamps on the hoses and re-set the ECU using the pedal method. Everything looks good. Hopefully it will stay that way. Thanks again guys
ClwMike
Jul 23, 2015 12:55 PM
vstypicals
Jul 20, 2015 10:55 PM
justgotg35
Jul 19, 2015 12:33 PM
igking
Jul 19, 2015 01:12 AM
mjfenix
Jul 17, 2015 02:07 PM
