Service Engine Light, Need Help!
Old May 13, 2007 | 11:45 AM
Omistry's Avatar
The other day when I was driving, my service engine light came one. I took the car to the dealer, and found out the error is from my senors that are attached to my headers. The dealer replaced the senors. When we looked below the car, I found out that my test pipes were cracked. Has anyone had this problem? I have Alphawreck headers, and I have had the headers and test pipes on for about 6 months. Furthermore, when we took the car into the shop, the maintance worker said that my car is using more fuel because the computer thinks the engine is not getting enough air from the injen intake.
For experts out there, do you have any suggestion? I am really confused, and also feel my car does not drive in full performance.
I am thinking about buying new test-pipes. Do you guys have an idea about the problem or where it is actually coming from?
Thanks.
Old May 13, 2007 | 11:56 AM
gspotter's Avatar
eBay test pipes?
Old May 13, 2007 | 11:58 AM
akachi's Avatar
Originally Posted by gspotter
eBay test pipes?
maybe that's why you're getting the check engine light...
Old May 13, 2007 | 12:59 PM
Rphillips6487's Avatar
its very common that your using more fuel becuase of your inejn cai. I have the same problem
GrayG35's Avatar
wow the dealer replaced your o2 sensors even though you had test pipes???
Old May 13, 2007 | 01:04 PM
Omistry's Avatar
Yes, sad to say.... ebay test pipes!
Old May 13, 2007 | 01:08 PM
FaDz's Avatar
VIP
my engine lite came on when i changed my headers...it was the O2 sensors... i dont know if it uses more fuel tho ??
Old May 13, 2007 | 01:41 PM
wuyichao's Avatar
is there a way to fix this?
im getting 17mpg, and i have injen cai...
Old May 13, 2007 | 02:37 PM
SILVERSURFERG35's Avatar
I have Strup Header ,Stillen cold intake , test pipes , full Greddy EvoII exhaust , lower plenum replacement and plenum spacer . During the winter months my Service Engine Soon light wouldn't stay off . I would get it reset like every three days . As in got warmer it doesn't come on anymore . The error code was " Bank One Sensor One " or the O/2 sensor . I have asked a lot of people and it is my understanding that any changes that are made may make the car not run right as far as fuel consumption . I was told that I will have to get some type of computer re-reflash of computer management to fix my fuel to air mix . I go through fuel like water to ! I hope that help !
Old May 13, 2007 | 03:15 PM
ttrank's Avatar
Grocery getter
You have two O2 sensors on each cat or test pipe. The first is to check the A/F, the second is only to see if the cat is working. If you have test pipes it is very common for the SES light to come on because it thinks your cat has failed. There is a non-fowler (sp?) fix for that which spaces the second sensor out a little.
As for the crack, that may also be causing the problem. If you have an exhaust leak you can have A/F issues which will lower your mpg.
I would take it to an exhaust shop and have them fix the crack.
Old May 13, 2007 | 03:24 PM
theres not really a way to fix it yourself. Its more of a chance to how your car reacts with the new cai. Either your car will adapt to the change or it will not understand why the car is getting to much air..and as a result add more fuel. so no, theres nothing you can really do, atleast from what ive heard.
I just bought a new injen cai in hope of fixing the problem. ill be installing it soon and ill post back to see if its fixed the problem
Old May 13, 2007 | 04:00 PM
Conscons's Avatar
i had the same problem too, so do you guys just leave the engine service soon light on???
Old May 25, 2007 | 03:15 PM
Conscons's Avatar
its pretty make me feel annoying~ i really wanna shut that light off~~
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Ednica87
Sep 5, 2015 02:59 AM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
