perfect set up for some hp gains
Old May 18, 2007 | 01:01 PM
seung012's Avatar
sup everyone. i posted up a thread about which exhaust between:HKS highpower, injen, fastintentions, stillen. i'm wanting a good NA result with the mods i have. Currently i have: jwt intake, z tube, crawford plenum, strup test pipes(on the way). people have said a lot of things about the different exhausts and how it is on preference. i like loud exhaust/aggressive look like the HKS/ most importantly HP gains. with the set up i have and the choices, what would be a better option? i'm going to boost in a little while and i was going to get 3inch custom exhaust made but decided not to and just order one. comments?
Old May 18, 2007 | 01:55 PM
seung012's Avatar
anyone?
Old May 18, 2007 | 02:27 PM
Beta99's Avatar
Unless you're in for just the look skip the exhaust and get the UTEC...search around and you'll find my dyno results w/ just the UTEC and res. test pipes.
Old May 18, 2007 | 02:57 PM
Beta99's Avatar
Plainly put it's used to squeeze more power out of the car and bolt-on mods such as i/e/h by fine tuning parameters like ignition, timing, a/f etc. It’s the kinda engine management that’s a must when you go FI but also offers plenty of gains when N/A.
I can flood you with more literature if you’d like
Old May 18, 2007 | 03:13 PM
Skaterbasist's Avatar
Retired SuperMod
UTEC is a waste of money if your planning on staying NA.
I can not justify paying $800 + tuning fees for what, 10 hp?
If your staying NA, do an ECU reflash. It corrects your AFR & gives you the extra power, depening on how rich or lean you are running.
Old May 18, 2007 | 03:23 PM
mbdizzle's Avatar
beta fill us in more with literature cuz i'm with skaterbiast on this one.
Old May 18, 2007 | 04:21 PM
ttrank's Avatar
Grocery getter
The best exhaust for HP seems to be the Stillen. The best looking goes to the Injen Ti and HKS Ti. The Stillen weighs more. IMO go with one of the Ti ones.
Old May 18, 2007 | 06:29 PM
Beebo's Avatar
FI will be making Ti exhaust soon yay
Old May 18, 2007 | 09:11 PM
Jim@Showstoppers's Avatar
I like the Injen Ti track edition.
Old May 23, 2007 | 11:26 AM
c.breeze_gt's Avatar
Lisa Fleming=HOT!!!
i cant bare the droning sound on the injen. thats why i plan on either gettin the fast intentions w/ ti tips whenever they make it, fuji w/ jic y-pipe, or the amuse.
Old May 23, 2007 | 12:39 PM
Beta99's Avatar
Here are some more info on the UTEC.
The Z UTEC is a Plug and Play Parallel Engine Management System. Designed to work together with you factory ECU. The UTEC gives you the ability to let the factory ECU drive the car under normal cruise conditions then take over when you are ready for the power in a flawless manor. This gives you like stock drive-ability with the advantages of a powerful stand-alone system. The UTEC allows you to maintain OBDII compliancy as well. The UTEC is unnoticeable to the OBD Scan process most states are adopting these days. In basic form we allow control over Fuel and Ignition Timing. Each control gives you 250 rpm resolution from 500 rpm to revlimit with over 10 different load sites. The UTEC will ship with pre-programmed base maps to help get you up and driving right away. In addition to having a pre-programmed base maps the UTEC has provisions for 5 different map locations. The multi-map capability allows you to use our remote map selector to switch between the 5 maps or stock mode on the fly. Your tuning options are endless when you can have a race map and daily driving map at the tip of your fingers. The power is all yours!
The easiest way to visualize it would be to break down it’s components into separate systems.
Fuel Control- The UTEC takes control of your vehicles fuelling at a define-able TPS point that is programmable. Fuel is tuned by an MAF offset table, a simple but effective technique. The load reference we use is RPM vs. MAF Voltage. The UTEC can also take in our optional MAP sensor to tune RPM vs. MAP or you can just use the MAP reading in your datalogs. This allows the fuel map to be adjusted at each of the 250 rpm resolution with over 10 different load sites from zero to rev limit.
Ignition Timing- The UTEC gives you complete control of timing. This is not done on the basis of offsets or altering the crank signal as some engine management systems use. The load reference we use is RPM vs. MAF or MAP which is optional. This allows the fuel map to be adjusted at each of the 250 rpm resolution with over 10 different load sites from zero to rev limit. When you enter a value into the Ignition Map you are actually typing in Degrees Before Top Dead Center. The UTEC fires the coils based on these values. No more wondering if the stock ecu is going to advance or retard timing.
Knock Control- This feature allows you to help keep your motor in one piece. The UTEC contains default knock thresholds but can be adjusted at 1000 rpm increments up to 9000 rpm. It also contains a Knock Count threshold that allows you to define how many counts of knock before the UTEC will respond with a Knock Retard Step. The Knock Retard Step is the amount of ignition timing that will be pulled per knock count to a defined Knock Maximum Retard. Knock Maximum Retard relates to the maximum degrees of timing the UTEC will retard per knock event. When a knock count is registered the UTEC will hold the retard for a set number of crank cycles this is called Knock Retard Duration. The UTEC also has the ability to apply a global Knock Correction to the entire map once a knock event is evident. This will help ensure that you keep your high compression monster together. All of these features are the UTEC’s safety net. They should be used pro-active not as a reactive measure.
Datalogging- The UTEC Datalogging function helps you to keep an eye on your engines vitals. Using the logger gives you all the information you want to know about your vehicle. You can take multiple logs of your vehicle whether it’s simple driveability or all out racing. You can be sure the UTEC is keeping an eye out when you can’t. The main logger (Number1) contains rpm, map, maf voltage, tps, load site, afr, ignition timing, injector duty cycle, modified fuel (fuel control) and more. Logs can be output into text files or csv files for easy comparison. When the UTEC is used with a TXS Tuner model it can also supply you with w/b afr readings in your logs as well. Giving you the ultimate tuning package.
Remote Map Selector- The remote selector gives you the capability to switch between your UTEC maps. It also allows you to revert back to full stock ecu control on map 0 (when stock sized injectors are used). Maps 1 through 5 are your UTEC tunable map locations. Map 7 is your security mode, the car will not start. The car cannot be bump started or jumped when security mode is enabled
Software Upgrade- The UTEC will have periodic software updates to further innovate it’s tunability and flexibility. The most current version of software will be available on our website www.turboxs.com.
The Z UTEC will be ideal for both Forced Induction and Naturally Aspirated Mods. The UTEC has the ability to control things like Nitrous, Water Injection and More!
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
imRACERX
19 Inch
Sep 10, 2015 08:53 AM
D1dphresh
Aug 7, 2015 06:10 PM
