View Poll Results: Best Midpipe Solution for a 2004 sedan?
Voters: 37. You may not vote on this poll
Best Midpipe Solution for a 2004 sedan.
Wanted yous guys' opinion on what the best midpipe solution for a bone stock exhaust on a 2004 Sedan. I'm most likely getting the HKS section in a few months, but if I find the tone off midpipe alone satisfactory I might hold off. from what i've read both coupe and 05/06 sedan midpipes could be direct swapped, which would be probably something I am interested in, and 350z pipe could work with an extender? Thanks for any input, tis greatly appreciated!
Originally Posted by DaveB
I've had both and the 05+ sedan midpipe sounds a lot better.
Originally Posted by w33ps
Any idea where I could pick one of those up? And as far as pricing...it seems like the coupe middys are being given away.
Originally Posted by black_sedan
what's the sound difference between the two? is one louder or deeper than the other?
Here's a video of the sound:
http://s147.photobucket.com/albums/r...6-10-07048.flv
Another advantage of the sedan midpipe is that it fits like stock. The coupe midpipe requires modification of the heat shields.
I like the way it sounds now with my 05+ sedan middy + 05+ sedan rear end
ease of fitment is def. a plus... if that matters to you, go with the newer sedan midpipe, unless you are positively sure that coupe will fit just as perfect. i'd still go with sedan midpipe IMO
I have a coupe middy...does it matter if I decide to get an HKS sport exhaust? Is the 05 resonator just as big as the 04s cuz the 04 is huge. If it is then there is a weight difference between the coupe and the sedans mid section. Coupe's mid section is very light compared to the 04s. So if your concerned about shaving some weight for performance would a coupe middy be better?
