So, about my Stillen Hi-flow Intake
Old Jul 23, 2007 | 09:09 PM
digitalhifinet's Avatar
I installed the Stillen hi-flow intake with a carbon fiber z tube, and I love it. I was wondering however about the bolt that inserts on the bottom of the intake. I have read here about it, but there was no mention in my Stillen instruction sheet, nor was there a hole on the bottom of the intake. Is this normal? Do I have an updated or outdated version? I actually ended up making a mount out of screw-able zip ties, so its all golden, but I'm just curios.
Here are some pics of my intake...
Old Jul 23, 2007 | 10:47 PM
TURBOTOM's Avatar
a.k.a kleicoupe
I think stillen stoped including this with there intakes cuz it was a PITA to get to, i dont have one on mine either.
Old Jul 23, 2007 | 10:51 PM
OCG35's Avatar
Interesting that they stopped using it... it is truly a PITA! I don’t know of anyone that bolts it down. Mine was bolted on first install but never subsequently... it's really not needed (especially for the effort it takes to get at it).
Old Jul 23, 2007 | 11:22 PM
Skaterbasist's Avatar
Retired SuperMod
Same here...
I didn't even bother bolting it down. Way too much of a hassle.
digitalhifinet, I wouldn't worry about it.
Old Jul 23, 2007 | 11:29 PM
Andy2434's Avatar
Same here . . . After the first cleaning, I did not reuse the bolt to tie down the bottom.
Old Jul 24, 2007 | 06:05 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
I agree, it was a complete PITA. I cut up my forearms, wrists reaching in there trying to screw in that bolt. Others have said you can use extentions for your socket wrench (although I can't believe how the angle of the socket extention actualy cleared the filter head).
This is what I did... I went to Lowes and bought a #8 double open ended bolt (its a machine bolt that doesn't have the socket head, imagine taking a mchine bolt and chopping off the head). I then measured roughly how long it would be to screw it into the car chasis, and fit the Stillen airbox over the screw. These screws come in 6" lengths so I think I cut of an inch or so off. Then, I tightened the screw into the car chasis using vice grip, fit the airbox over the screw, then used a nut to tighten down the box. Much easier IMO. Total cost, 35 cents.....lacerations and cuts to the wrist and forearms avoided...priceless.
Although the description of this process seems complicated, it really only took 5 minutes to do.. lol.
doc
Old Jul 26, 2007 | 07:30 AM
cato's Avatar
SouthernComfort Moderator
Same here. After first install, never used it again. Stillen finally got the message.
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
vamarris
Sep 26, 2015 12:56 PM
