exhaust for Turbo?
Old Feb 4, 2004 | 03:56 AM
nuttyprof's Avatar
exhaust for Turbo?
what type of exhaust would be best for a Twin Turbo application? im hoping to get TT someday, but i want to get an exhaust now. BTW, this is for a sedan. i have heard that a single pipe system would be better. or perhaps a straight pipe with test pipes but that definitely wouldnt pass smog. how do you guys think the Stillen True Dual would be for TT?
G35S 6MT
Technosquare ECU
350Z Springs & Struts
6-wire ground kit
Old Feb 4, 2004 | 09:57 AM
DaveO's Avatar
Re: exhaust for Turbo?
I asked the same question when I toured Stillen's manufacturing facility.
Both the Stillen Sedan & Coupe exhaust systems are designed for the additional gas flow provided by forced induction.
2003 G35 Sedan - DP / Willow / AT / Premium / Sport
350Z Engine Cover, T-Stat & Air Duct / Stillen CAI
GG 7-Wire H-G Kit / TechnoSquare ECU / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
Old Feb 4, 2004 | 10:57 AM
waijai's Avatar
i.love.gold
Large piping ... 3" is good...some big turbo Supras use 4" piping.
Ivory Pearl coupe
Old Feb 4, 2004 | 04:22 PM
infidsg35's Avatar
Bigger the piping the better. You want the freest flowing exhaust. I heard the Borla was probably the best as it loses HP and Torque at low RMPS witch means that it is VERY free flowing since the car lost HP due to no backpressure!!!
Hope this helps...
5 wire Grounding kit
350z Pipe / Stillen High-Flow
JUN Flywheel
Crawford Intake Manifold
Yellow Top Optima Battery
Best 1/4 14.153 @ 99.19 / 2.29 - 60'
Old Feb 4, 2004 | 09:13 PM
nuttyprof's Avatar
so that means no on the stillen true dual then? isnt that like 2.25 inch or 2.5 inch. hmm, maybe i should do a custom job. i know a place that will build me a straight pipe type exhaust for 6 bills. quality work too. 3 inch all the way through. throw on some high flow cats. maybe i can shoot out flames. is this logic correct?
G35S 6MT
Technosquare ECU
6-wire ground kit
Old Feb 5, 2004 | 08:08 AM
1PHATG35's Avatar
I'd recommend the Fuji exhaust,w/ the "Y" pipe, and race pipes, the Fuji is a full 3" and will flow more than you will need even w/ the TT setup. The big Pupras w/ the 4" exhausts have big single turbo swaps pushing well over 700+ whp ie. T88's, T72's, or maybe Twin 3037's. And our G's will never reach that kind of play. Good Luck!!
~B
~B
Old Feb 5, 2004 | 03:05 PM
str8dum's Avatar
but if u get that big of an exhaust now, your low end will feel like [censored]. sluggish and little power. yeah that will be cool (not!!)
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
