Regarding stock intake
Old Sep 23, 2007 | 11:30 PM
Otacon132's Avatar
I just recently swapped back in my stock intake, im getting a stillen sometime very soon.
Theres a part of the intake that i pretty much left...off heh - not sure where it goes, anyways - i noticed on the stillen intake theres that same hole and now im wondering what its used for and if i even need it.
heres a pic for reference - its the center piece, that round hole on the bottom section.
Old Sep 23, 2007 | 11:32 PM
g35brandon's Avatar
not positive, but I think there should be a rubber gromet that goes in there for placement. I would have to double check though...
Old Sep 23, 2007 | 11:53 PM
Otacon132's Avatar
the piece that i have left over fits that hole....its kinda like a catcher of some sort - with a small hole on the bottom, only thing i could THINK is to drain ...water...which shouldnt be in that "intake" area in the first place!
if anyone has any idea what its for - or if i should worry about it let me know =P
Old Sep 24, 2007 | 12:35 AM
ISMSOLUTIONS's Avatar
It's a sound baffle, like the stock tubes have. If you don't use it, it will be a little louder, but promote heat soak as well.
You can cap off/seal the hole and not use as well.
Rick
Old Sep 24, 2007 | 12:43 AM
Otacon132's Avatar
thanks for the info - gonna just find a way to seal it then
Old Sep 24, 2007 | 12:46 AM
Get a 1.5" plumbers plug. Rubber gromet, about 1.5" diameter and 1-2" thick with a blot running through it. You tighten the bolt and it expands - sealing the hole.
They run about $3 at Lowes.
Rick
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
Daniel k.
Nov 3, 2015 09:52 AM
RA081024
Sep 7, 2015 01:29 AM
